Old 08-19-2008, 07:35 PM
My bad, good catch. I forgot to mention that if the spare was used and switched out, the wheel with the transmitter would be under/in the bed and if/when low will set the indicator off as well.
At any rate it is possible and can be the case however remote.
Old 08-19-2008, 08:26 PM
Zero Six LE's Avatar
The transmitters have to be in motion to work. That's why you have to drive the truck above 16 mph after adding air or other service involving the tires and wheels.
02 Maxima SE Tungsten Blue
Old 08-20-2008, 05:54 AM
That would be partially correct sir. The vehicle has to be in motion (running), not the sensors to initiate or clear the system.
Also, for sake of what was originally stated, I still don't believe the OP should be alarming at 31 psi.
Since he (?) and I are '05s (NISMO here) and yours is an '06 (LE also) what does your manual state?
Thanks again Zero, I had my replies mixed up between blackwaterstout and speedfrog. Read as both from OP.
Originally Posted by speedfrog View Post
I'm having a problem with mine staying on at the moment...I think It might be from the spair tire being on from where I busted a tire wheeling yesterday
Should be your remedy. Once you replace the TPMS wheel, properly aired the light should go out.
Old 08-20-2008, 06:52 AM
Also, if your tires are over 42 psi it will make the light come on.
Old 08-20-2008, 08:59 AM
Thats why I believe I may have a problem with my TPMS. I had all 4 tires reading at 35psi and drove my truck over 10 miles on the interstate. The light should have went off.
Old 08-20-2008, 10:59 AM
speedfrog's Avatar
Send a message via Yahoo to speedfrog
That would be partially incorrect sir. They have to be in motion to reset the light, not initiate it.
I know...waiting on my 33/11.50 16s at the moment
"Don't tell God how big your storm is, tell the storm how big your God is."
Blacktop Rollin? only between trail rides
www.myspace.com/speedfrog
Old 09-07-2008, 03:52 PM
Diamond_dave's Avatar
nobody really answered the question. Is it possible to reset without visiting the steatler?
Thanlks
Old 09-07-2008, 04:08 PM
blitzburghnut's Avatar
Thanlks
from what i understand . the dealer has to reprogram the ecu.
2007 kc se 4x4
2.0 radflo's 1.5 prg block rancho 9000xl shock
nismo wheels
firestone destination m/t 265/75/16
GO STEELERS
  #19 (permalink)
Old 09-08-2008, 07:27 AM
I forgot to update this thread after getting my tire plugged. Sure enough they plugged my tire and the TPMS light finally went out but it took about 15 miles of highway driving for it to happen. I can't explain it but it did eventually go out.
The Following User Says Thank You to blackwaterstout For This Useful Post:
Zero Six LE (09-08-2008)
