Rear-end whining and clicking - Nissan Frontier / Navara Forum
Old 11-18-2012, 02:35 AM
Hi guys, I have a 2005 Frontier, 2WD, Manual, 120K.
Recently, the rear end started making a repetitive clicking a noise from 0mph to 60+ and also a loud whining noise that progressively gets louder from 30mph on up. When I let off the gas the whining noise stops.
Does any one know what the problem is or what may be about to fail? Also how much work might go into fixing it, Thanks!
** Background information - I recently pulled a trailer for a long distance, half way through the trip I blew a rear axel seal. It was repaired but I am sure what ever is wrong is probably from my trip.
Old 11-18-2012, 12:13 PM
dubie2003's Avatar
Have you isolated it to the diff and only the diff? Have you coasted in neutral (clutch pedal in) to see if the noise is still there?
The clicking/whine could be the gears themselves, U-joints, etc...
How long was it run with the fluid low? Was there chucks or only shavings in the diff? How heavy was the trailer?
There are a lot of things that come into play. We need a lot more information to help give you true direction, without it you get the shotgun effect which is basically, check everything....
07 SE CC Auto
Old 11-18-2012, 12:48 PM
Mandangalo's Avatar
I'm gonna go out on a limb and say pinion bearing. There are 2, and based on the history and the symptoms that's what it sounds like to me.
I forget which it is but if one bearing is bad it will whine/squeal when u hit the gas. If the other is bad it will do the same during coasting. I wouldn't start opening it up till an axle shop confirms that is the issue
The Following User Says Thank You to Mandangalo For This Useful Post:
StormFrontier (11-19-2012)
Old 11-18-2012, 10:22 PM
upflying's Avatar
The blown axle seal could have spilled enough gear oil to starve the pinion bearing for oil.
2010 Frontier Crew Cab SE long bed 4X2, avalanche
1986 Chevrolet Monte Carlo SS, stock
Old 11-18-2012, 10:33 PM
Thanks Dubie2003, I will do the neutral test tomorrow. I am not sure how long the fluid was low but I dont think it was too long, it had fresh Amzoil fluid in it. I asked the mechanic if there was metal in the oil and he said it looked normal. The trailer was probably 4000lbs max?
Mandangalo sorry for the newb question, but where is the pinion bearing?
Old 11-18-2012, 11:24 PM
upflying's Avatar
Old 11-19-2012, 06:30 AM
Mandangalo's Avatar
On the pinion shaft, inside the diff. One is right behind the pinion seal
Old 11-19-2012, 10:19 AM
StormFrontier's Avatar
Mine has been whining real bad for a while now, but it's opposite of yours in the sense that it makes noise when I'm coasting and turning right. I'm pretty sure it's the pinion bearing as well.
<-Old truck. Now have a 2012 Xterra Pro-4X
Jordan, ME (EIT)
SmugMug Frontier Pics
2008 Storm Gray SE CC 4x4 6spd
See my garage for list of mods.
Old 11-21-2012, 11:14 PM
Dubie2003 - I coasted in neutral and both noises go away. What does that mean?
Old 11-22-2012, 10:04 AM
U-joint.
