Proper Way to Shift_ Into 4WD
Hello!
4WD (Obviously) 03 Nissan Crew Cab XE Longbed. Automatic with the shifter coming out of the floor NOT on the steering column. I have the manual shift (not just the little turn dial) though for switching between 2WD, 4H, N, and 4L. Whats the proper procedure for popping it into 4WD? |
4 Hi you can do on the fly...I am pretty sure.....
4 low you need to stop, put the tranny in neutral, and then shift into 4 low. Coming out of 4 wheel drive, reverse 10 feet or so to let the hubs unlock.
![]() 1994 Pathfinder SE 4A 4x4. Mall Crawler. 2007 NISMO KC 6M 4x4 - Gone 2005 SE KC 6M 2x4 - Gone 2002 SE CC 4A 2x4 - Gone ONAZ Last edited by Inyourface1650 : 12-15-2007 at 03:36 PM. |
Ah thanks. I went from 4H and switched back and went to 2WD and it didnt say it switched back on the dash. Moved it back and forth a couple times and moved foward a bit and it changed. Am I still ok?
Went to an old abanoned property to check out if thise lake was frozen yet and had some fun on the grass. Must say the long beds throw a nice whip! |
Thats why if I am in a vehicle with hubs I will just reverse it until the light goes off.. Pops out every time
![]() 1994 Pathfinder SE 4A 4x4. Mall Crawler. 2007 NISMO KC 6M 4x4 - Gone 2005 SE KC 6M 2x4 - Gone 2002 SE CC 4A 2x4 - Gone ONAZ Last edited by Inyourface1650 : 12-15-2007 at 03:45 PM. |
Ah ok. I just didnt want to be driving down the highway, wondering what that horrible noise was, and what Im doing looking at a transfer case behind me.
