Old 07-17-2006, 09:55 PM
Noise from the rear
Has anyone had any issues with a noise coming from the rear of the truck. I sounds like something is loose it kindve shutters. I can hear it when the rear wheels hit a bump at different times. I have been to the dealer and they said everything is ok and tight.
Any ideas????
06 Frontier CC SE 4X4 Silver
Old 07-17-2006, 09:58 PM
konarider's Avatar
check the bed extender if you have one...
check it out...thanks!
http://www.cardomain.com/ride/2373107
Old 07-17-2006, 10:16 PM
mike's Avatar
this
http://www.nissanhelp.com/Ownership/.../NTB06-030.htm
or this
http://www.nissanhelp.com/Ownership/.../NTB05-117.htm
Old 07-17-2006, 10:20 PM
It is definately not a squeak. It sounds like heavy metal pieces banging together.
Old 07-17-2006, 10:22 PM
gfronty05's Avatar
Maybe the leaf spring pack is loose, take it to another dealer and get a second opinion!
Old 07-17-2006, 11:00 PM
Frontier2's Avatar
I heard mine making that noise going too going over bumps on the interstate.The sound was bouncing off the walls so i couldn't tell what was making the noise.I'll have too wait til i get it on the lift too look for the noise.
06 MAJESTIC BLUE 4X2 LE KC
Old 07-18-2006, 10:24 AM
peter's Avatar
Any ideas????
Hi I have the same noise, my dealer also checked that every thing was tight and could find nothing. I am starting to suspect that its the tailgate.
Regards
Peter
Old 07-18-2006, 11:06 AM
Benzo's Avatar
I have a very similar noise over bumps. You can almost duplicate if you go over the bump kind of side ways. Seems to be a normal thing. Dealership said everything was good. My truck has 460 miles on it now. ADAM
2006 Frontier SE 4x4 Storm Gray,Chrome Door Handles, Scan Gauge II, 9" Antenna,Bug Gaurd,Truxedo Low Pro Tanneau cover, 30% Tint, Billet Grilles....ect
Old 07-18-2006, 11:11 AM
Panman06's Avatar
Two things I've noticed. One: If you have a bed extender, check the webbing strap that secures the extender to the tailgate. The straps tend to hit the extender while driving. Two: Some FronT have a weight attached on the exhaust. This will sometimes hit the frame when driving.
'06 SE Crew 4WD 6MT...um...completely stock
Old 07-18-2006, 01:16 PM
Mine makes the same noise. It's not some I worry about because when I use to drive my '95 Sonoma 4x4 5sp manual through a drivethru or an enclosed area like a parking garage there was SO MUCH backlash in the drivetrain that it sounded like I was driving a IH tractor or something. It was pretty ratty.
When I brought this up to my dealer he said to ride the clutch more to dampend the noise.......lol........idiots!!
