Old 12-21-2007, 03:17 PM
Maximum/Biggest Tire Size for '08 Frontier?
I just ordered an '08 Nismo King.. (yay!) I want to pimp it out right away, but don't know what to do about tires & wheels.. Does anyone know the widest tire that will fit before you start to bump into other stuff? What about the largest diameter without a lift? Ideally I'd like to do 285/70-18s, that would be a 7.9" sidewall, 16.9" radius, and be 33.7" diameter.. which is about a 6.5% rolling radius increase over the 265/75-16s that come installed from the factory. (265/75-16 is 7.8" sidewall, 15.8" radius, and 31.6" diameter). Does anyone know if this will fit at maximum articulation of the suspension? Also, does anyone have experience with speedometer recalibration?
I'm guessing that the 285s will be fine, since that's only 4/5" wider or so total (or about 2/5ths on either side of center).. it's the aggregate increase in diameter of 2 inches that concerns me.
Thanks..
Old 12-21-2007, 03:20 PM
Inyourface1650's Avatar
Hey man, most of this could be answered if you did a bit of searching...but anyway.
Your pretty much going to need to lift it if you want to go higher than stock tire size. 285's will definitely rub. However, if you do plan on wheeling anyway, I would recommend a lift, which will then let you fit 33's (285/75R16) on with ease....These trucks are very low in the front.
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Old 12-21-2007, 04:01 PM
Slee_Stack's Avatar
33.7" dia will be a rub-o-rama w/o a lift. Mine had mudflap rub at 31.9".
Geometry of the tires shoulders/tread also plays a role.
Plan for a lift first, then do your wheels/tires.
2005 CC LE: 20" MB Predators, 275/55-20 Kumho Ectsa STX, Traction Mod, Air Box Mod, Grounding Kit, Carriage Works Billet Grill, Pathfinder Switch Plates, JVC KD-LHX550 H.U., Boston Acoustics mids, (2) JL 8W3v2 and JL Amp.
Old 12-21-2007, 04:16 PM
Mr. Plow's Avatar
Agreed, I think there have been more discussions on this topic than any other, but yes get a 3" lift and go grab some new wheels and 33's. Even then expect to have rubbing depending on type of tire you get (square shouldered tires rub more than rounded ones), so you may have to take a heat gun to the plastic fender liner.
Silver 06 Frontier KC NISMO 4x4. Mods: PRG Radflo 2.5" SL; Deaver 10 Leaf Springs; AC Rear Diff Skid; Shrockworks Sliders/Skids; KMA Front/Rear Bumpers; Warn M8000 Winch and Offroad Lights; Gibson Exhaust; Interco Trxus MTs 285/75/R16 on MB Predators
Old 12-21-2007, 04:20 PM
REDNISMOCRU's Avatar
X3 on the lift. Get the 3" spacer from PRG and you will be very Happy IMO
Roby
2006 NISMO CC: 7" Total lift, all from Greg @ PRG= 4" CST Spindles, 3" PRG Spacers, SS Brake lines, Deavers, PRG Adjustable Shackles, 1.5 blocks, and Bilstein 5125's. 285/75 BFG AT's, Pathy Swithcovers, OEM Step rails, Airbox mod w/K&N filter, Flowmaster 50 SUV w/ Duals, PIAA SuperPlasma GTX bulbs, V1 Radar, Sony Xplod 6x9's, TomTom Go700 GPS, and 3 Graco Carseats.
DAILY DRIVER: 2006 Butante Blue Dodge Grand Caravan SE w/ Sirius, TomTom Go 700, Valentine1. BEST MOD = Free GA$
