Max Weight You'd Put In The Bed? - Page 3 - Nissan Frontier Forum
 1Likes
post #21 of 79 (permalink) Old 10-08-2010, 07:27 PM
Banned
Send a message via Yahoo to t2stone
Originally Posted by 4Point0 View Post
Rent the van from Home Depot and do it in one trip assuming the drive is long.
That would be my choice!
T.C.
t2stone is offline
post #22 of 79 (permalink) Old 10-08-2010, 07:43 PM
Dana_15's Avatar
Originally Posted by Mainerunr View Post
OP: seeing you're in MA, 4 trips, maybe 5, people drive like idiots down there.
Thats the truth!
2014 Titan PRO4X
2011 G37X
Dana_15 is offline
post #23 of 79 (permalink) Old 10-08-2010, 08:32 PM
Mainerunr's Avatar
fail if the 'van' is anything like the 'truck', they have weight sensors, had to make two trips with drywall, if you're over weight the truck wont even start.
'05 Storm Gray SE CC 4x4, 6M. PRG 2" f/r, OEM fogs/skids, 265/75r16 Yokohama Geolandar AT/S, stubbie antenna. (GONE)
'11 F150, Ingot Silver XLT Off-Road Supercrew 275/65/18 Toyo AT2's
Mainerunr is offline
post #24 of 79 (permalink) Old 10-08-2010, 09:10 PM
Quoted: 11 Post(s)
I had 2500 pounds of loam in the bed. Home was only 4 miles so it did OK but any bump would max out the suspension unless I drove judiciously.
2WD_NISMO is offline
post #25 of 79 (permalink) Old 10-09-2010, 01:45 PM
frontier4life2008's Avatar
Well, with my $450 leaf spring upgrade 1000lbs dropped my truck about an inch. I agree that if you drive slow and your not traveling a long ways you can do it in three trips
2007 4X4 SE Crew Cab Long Bed, 6 Speed. Brute Force Intake. 2in lift with custom springs in rear 285/75R16 Pro Comp xtreme AT's
frontier4life2008 is offline
post #26 of 79 (permalink) Old 10-12-2010, 12:58 PM Thread Starter
Ended up getting 41 bags (80 lbs each). Did 3 trips total. The first 2 were 12 bags each. The truck almost seemed unaffected by it, so when I ended up needing a few bags less than I thought I decided to do the final 17 in one load. I only live 5-7 minutes from the place, so… It didn’t drive much different . A little slow on the brakes and I was more careful on the cornering, but all in all it handled it really well. But, with 17 in there, it was visibly weighed down in the back. I wouldn’t do it for a far trip.
Thanks everyone!
Old: 2010 Nissan Frontier: Black, Crew Cab, SE, 4X4, Value Truck Page, Moon Roof
New: 2014 Nissan Frontier: Black, Crew Cab, SV, 4X4, Value Truck Page
MSmith is offline
post #27 of 79 (permalink) Old 02-16-2013, 08:16 PM
goody's Avatar
Quoted: 3 Post(s)
I just did 2140 lbs of paver stone in the bed, 80lbs of dog food in the cab along with 710 lbs of people...was mostly a short highway trip, but handled it well.
2006 Storm Grey CC LE, Traded
2014 CC SV Glacier white w/value package
Tan Colored Weathertech digital floormats for sale (front and back for CC)
Originally Posted by BRUTAL View Post
well we dont have a RTFM icon around here.
goody is offline
post #28 of 79 (permalink) Old 02-16-2013, 10:09 PM
Mathster's Avatar
Quoted: 95 Post(s)
been a couple years on this one. yeah, the truck can handle the weight, but its all about liabilities. If you crash and are overweight, your insurer is gonna hang you out to dry.
Roll across a scale, see what your truck weighs. stay under your data plate and you'll stay legal. Overload and its on you. Yeah, I've rolled the dice a few times with my truck. sometimes, you gotta do it.
13CC4x4SV
Mathster is offline
post #29 of 79 (permalink) Old 02-17-2013, 01:10 PM
You know there are giant concrete trucks that deliver that stuff, its cheap enough for the time savings.
How long is the drive?
www.nissanwheelers.com
JUST FRIGGIN BY-PASS!!
chainsaw is offline
post #30 of 79 (permalink) Old 01-26-2014, 12:45 AM
1 Ton of BioBricks too much???
I did some searching on the forum before going to pick up 1 ton of bio bricks for our wood stove to know whether or not I might be overloading it and found most people said in several threads that they easy did 2k lbs and some even slightly more, 2.5k lbs. Not knowing what their particular setup was (stock suspension or AAL's or blocks or custom leaf packs) I took it to mean as a stocker or even modified I would be fine as I assumed there must be a mix of those examples in all those threads.
I'm setup with 3" lift with Radflo's up front and a custom pack from Alcan in the rear (built for addition 100 lbs, although I usually don't ride with anything extra). Also I have a good amount of rake to my setup. Went to pick up the bricks and when the guy set the pallet in the bed it squatted what looked to be really low, I must have been really close to the bump stops, although I didn't actually check. I did see that my leaf pack was inverted and that scared me so I had them remove it and I split the load by hand and made two trips. My wife was up front and said it felt bad from her perspective, I guess she started to point up, lol.
So my question is, was I over reacting? I heard in my experience researching leaf packs that they should never be inverted for long periods. I know articulating off road may invert them when you stuff a wheel, but again that is not long term, ie driving home 30 miles as I was.
Or is it because I have the custom leaf pack from Alcan that I lost some payload capacity?... perhaps because Alcan mfg's the spring to have more flex thus loosing some payload compared to stock or those with AALs or blocks or some combination?
Thanks in advance for your input!
JRunner01 is offline
