Old 08-14-2008, 04:45 PM
I had 16 concrete deck blocks in the back, each weighed around 100 lbs. With about 1600 lbs in the back, the truck was squatting pretty good, almost at the suspension stops. It drove perfectly fine, so I'd think with helper springs you could carry quite a bit more.
2006 Frontier Storm Gray Crew Cab 4x4 Auto
Old 08-15-2008, 01:59 AM
so the general consensus here is that its the springs that are keeping the weight to a certain limit.
Old 08-15-2008, 04:58 AM
Tweak'e's Avatar
no.
springs are easily fixed to suit the weight. the real limit is the chassis. to much weight and you start cracking the chassis. for eg later nissan patrols have been having that problem (i suspect nissan fitted a lighter chassis in th later models).
Old 08-16-2008, 11:47 PM
oohhh so I was under the impression that we were using the titan frame or something like that which should be able to take the added weight. So that was all marketing b.s.?
Old 08-17-2008, 12:12 AM
Inyourface1650's Avatar
We use a shortened version of the titan frame, but it might be thinner gauge steel, who knows.
I hope you did read all the posts in this thread carefully. What are you trying to do? If you carry a 2 ton load once or twice it probably wont hurt anything, but if you are even thinking of doing it on a regular basis, you are driving the wrong vehicle.
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Last edited by Inyourface1650 : 08-17-2008 at 12:14 AM. Reason: Automerged Doublepost
The Following User Says Thank You to Inyourface1650 For This Useful Post:
dubie2003 (08-17-2008)
Old 08-17-2008, 12:24 AM
Yeah its all good, I'm only asking for the sake of knowing. You never know when this bit of info might come in handy. Thanks for all the input guys.
Old 08-17-2008, 01:48 AM
Tweak'e's Avatar
its depends on what exactly they have done. it may be a cut down titan chassi or one simply based on the design. its common these days to cut down anything and everything to gain a performance and economy edge.
also don't forget type of road (or lack of road), load distribution, plus driving style has a huge impact on physical limits of the vehicle.
double cabs are really bad for having a lot of weight simply because the weight on the deck is placed past the rear axle.
edit: D22 in my advatar has excess of 2000lbs on the back of it but because of where it sits the vechile handles it fine.
