Intermittent long cranking start-up - Nissan Frontier Forum
post #1 of 10 (permalink) Old 03-19-2017, 06:15 PM Thread Starter
Quoted: 2 Post(s)
Hi Folks,
I'll just get into it:
Nissan 2006 Frontier LE Crew V6 just over 43,000 miles (work from home).
Engine was running fine.
I thought, "she's a great truck, I'm going to give her some Lucas fuel injector cleaner as a treat".
NOPE! WRONG! My dumb a** put in the bottle of Lucas without filling up the tank. So it was only about 1/2 full of gas and didn't have a chance to dilute. I have used the exact same product for years without issue, my fault this time.
ANYWAYS, right after I started up my kid, ran fine for a few blocks, then engine quits. Pull over, checked everything, no leaks, etc etc.
Gave it 5 minutes then after about 10 seconds of cranking she started back up.
That was about 2 weeks ago (for me that means about 30 miles ago-ish).
Now she's intermittent on the long cold crank starts. Sometimes it's immediately starting, sometimes she needs a few gasps to go.
"Priming" the system (turn key to ignition just shy of cranking the starter, turn off, pull keys out, repeat process 2-3 times) does reduce the amount of cranking.
My guess (and I'd love some feedback here):
- Lucas-goo honked-up my fuel filter
I have run 1/2 tank of premium gas through her. I'm wondering if a fuel system cleaner might be a good idea.
TIA
2006funteering is offline
post #2 of 10 (permalink) Old 03-19-2017, 07:01 PM
yesterdaysradios's Avatar
Quoted: 234 Post(s)
Isn't that what you did to get you to this point? Just say no to ANY mechanic in a bottle. Your owners manual even says not to use fuel system cleaners/additives. My 2010 has 35k (not my only vehicle) and I'd never consider using a fuel system cleaner in any of my vehicles. Why? Because they're not needed. Simply buy your fuel at a newer recognized brand high volume station.
Is the check engine light on? Other than suggesting to drive it and hopefully the problem clears up after you have run some clean fresh fuel through it (doesn't have to be premium) I don't know what else to advise you to do.
2010 Frontier SE V6 CC LWB 4x2, built 04-2010, purchased 07-2010
Current mods: OEM foglight kit, WeatherTech molded floor mats f/r, locking gas cap, OEM locking lug nuts, Clarion CX501 and Sirius Connect SC-C1, OEM mud flaps/splash guards, 3in. round blind spot mirrors, Nissan logo valve stem caps, rad/trans cooler bypass, rear axle vent mod, custom lower grill insert using black mesh gutter guard material, OEM auto dim rearview mirror w/temp & compass, OEM hood protector/bug shield, 35% tint on both front windows and a windshield strip, OEM body side molding, OEM step rails, 7in. tall metal radio antenna, OEM front tow hooks (true left and right hook), OEM rope hooks in the bed, OEM special edition emblem added to tailgate.
yesterdaysradios is offline
The Following User Says Thank You to yesterdaysradios For This Useful Post:
2006funteering (03-20-2017)
post #3 of 10 (permalink) Old 03-19-2017, 07:55 PM
Administrator
2013Pro4X's Avatar
Quoted: 935 Post(s)
My thought would be to start by running through a few tankfuls of fresh gas (no external additives), then reevaluate to see if the symptoms still persist, and or if any trouble codes show up.
-- Brian
'13 Pro4X CC / AT, BFG KO2s 265-75-16, BakflipG2, Curt Hitch, Pathy Plates, OEM Steps & Bug Deflector, 20% 3M Color Stable Tint, 7pin Trailer Plug Mounted in Bumper Mod, Powerstop Z23 Rotors & Pads
2013Pro4X is offline
The Following User Says Thank You to 2013Pro4X For This Useful Post:
post #4 of 10 (permalink) Old 03-19-2017, 08:19 PM
Zero Six LE's Avatar
Quoted: 889 Post(s)
It might be related to ECM relay under the hood. There was a recall in 2010 to replace the relay in the IPDM. Read this recall notice. 2005 Nissan Frontier Recall for Engine And Engine Cooling Problem #10V517000
Zero Six LE is offline
The Following 3 Users Say Thank You to Zero Six LE For This Useful Post:
2006funteering (03-20-2017), 2013Pro4X (03-19-2017), Zedbra (03-19-2017)
post #5 of 10 (permalink) Old 03-20-2017, 07:25 PM Thread Starter
Quoted: 2 Post(s)
Lucas wasn't the issue, strange timing...
So I had my truck scanned, this is the only error that came up: camshaft position sensor, bank 2 (left side of engine looking forward in driver's POV). The error P0345 popped up twice (that's what the "1 of 2" is).
I'm hoping it was wanged or the contacts are corroded. Otherwise that little guy is about $65.
You can see location from the factory service manual, attached.
Thoughts?
ID:	237697   Click image for larger version
Name:	3-20-2017 5-17-18 PM.jpg
The Following 2 Users Say Thank You to 2006funteering For This Useful Post:
2013Pro4X (03-20-2017), Zero Six LE (03-20-2017)
post #6 of 10 (permalink) Old 03-20-2017, 08:03 PM
Quoted: 889 Post(s)
Thoughts?
That's another thing that can cause stalling. I would strongly advise you get the OEM sensor to replace it. My trusted Nissan tech told me that aftermarket sensors are not always viable replacements. He has worked on Nissans for well over a decade. A friend of mine with a 08 Frontier had to replace one of his sensors late last year. I am fortunate enough to still have my original sensors with 143,000 plus miles on the engine.
The Following 2 Users Say Thank You to Zero Six LE For This Useful Post:
2006funteering (03-20-2017), 2013Pro4X (03-20-2017)
post #7 of 10 (permalink) Old 03-20-2017, 08:14 PM Thread Starter
Quoted: 2 Post(s)
Lucky!!!!!
Just disconnected the battery, found the little bugger, and jiggled it (actually tried to get the connector off to check for corrosion).
By only jiggling the connector the problem is solved! For now....
My guess is the sensor is OK, just have some corrosion on the pins. Now, to get that connector off...I have gorilla hands and this is a super-tight space to work in. Get it off, clean the pins, apply some yummy GC electronics silicone compound and slide those electron-lovers back together.
Thanks for the heads-up on the OEM sensors.
Cheers folks!
post #8 of 10 (permalink) Old 03-20-2017, 08:27 PM
Lil' Fronty's Avatar
Quoted: 84 Post(s)
Yikes! That looks like it is going to cost money!
Where it's at looks like a snake of money is going to be needed (not lololing at all to this because I feel bad for you) I would think that the fuel injector cleaner stuff would be the problem also. The funny thing is that before I bought my new Fronty, I did some research about good fuel and bad fuel and that no 2 fuels are the same. If you use gas that has a lot of detergents in the gas like Costco or Shell, then there is no need to worry about clogged fuel injectors. If you feed your car with cheap gas like Kroger, Walmart, or those off brand convenience store gas station, then expect your fuel injectors to be clogged. I see why though that you are worried about your fuel injectors. According to my research, these fuel injectors in cars are the size of the human hair so practically, anything can clog it. Also since Fronty's use only regualr unleaded gas, it is pointless to spend that extra dollar on premium gas because your truck does not have a sports engine. Yes premium is a more refined gas than regular, but it is not going to do you any better. My mom used to fill her Nissan Altima with premium until I told her that you are wasting money on premium. If you do not need it, do not buy it! (that is how I live my life). I hope that this advice helps you
2016 Nissan Frontier S 4x2 Auto bone stock 4 lyfe!!!
"Your window cranks itself down electronically. I have to crank mines the old fashion way: manually "
The most useful button at night for a trucker:
Lil' Fronty is offline
The Following User Says Thank You to Lil' Fronty For This Useful Post:
post #9 of 10 (permalink) Old 03-20-2017, 08:36 PM Thread Starter
Quoted: 2 Post(s)
yeeeeaaahhh...good advice, but it turned out that was not the problem. Cheers!
The Following User Says Thank You to 2006funteering For This Useful Post:
Lil' Fronty (03-20-2017)
post #10 of 10 (permalink) Old 03-20-2017, 09:36 PM
Administrator
2013Pro4X's Avatar
Quoted: 935 Post(s)
Appreciate the follow up after finding the issue OP!
-- Brian
