» Sponsors
» Sponsors
Closed Thread
  #21 (permalink)
Old 03-20-2008, 08:49 PM
UpFront's Avatar
Originally Posted by UpFront View Post
Yeah, I used the gaskets that came with the IMS. I still have the oil pressure prob. so, I gotta take it in to the dealer. That is one of the reasons I took off the IMS. I didn't want it on there when I took it in. I have heard of some others having the same problem with the pressure reading high and it ended up being a sensor or something. Scary none the less.
Took the truck into the dealer and the oil pressure thing is normal, when the truck is cold the needle is supposed to move in relation to engine speed... higher speed = higher reading. So, I still don't know what the deal is with the IMS gaskets. I don't know why they went bad. I would like to get some fresh ones and try it again. Nobody has wrenched theirs off to take a look?.. Brutal? I'm still curious if I'm the only one with the gasket problem.
2006 Black CC 6spd SE - Flowmaster 50 SUV - Volant Intake - Throttle Body Spacer - Intake Manifold Spacer - Scanguage 2 - OEM Hood Protector - Nismo Shift Knob - Pathfinder Window Switches.
  #22 (permalink)
Old 03-20-2008, 09:29 PM
BRUTAL's Avatar
No I havent had a chance yet, installed new front door, tiled the entry, and tileing the back now, nice way to spend a weeks vacation huh, and least the weathers nice and I can drink margaritas while I work
OMF street-locked Nismo wheels
Shrock skids, winch bumper, 9500# winch.PRG 10 leaf packs, Radflos, TC upper arms.
KN CAI, BFG KM2 305/70/16
Confer roof rack, aluminum tool boxes, Piaa 525 driving/fog, projector HID headlights, and fogs, Carbon fiber grill CF hood, sliders, crossdrilled rotors, EBC pads, 1 touch windows. trans VB modded, modifyed STILLEN SUPER CHARGER, 330 RWHP, NISMO T stat, UPREV http://www.youtube.com/watch?v=Sn1EvGKO1Yo
  #23 (permalink)
Old 03-21-2008, 10:40 AM
toyniss's Avatar
i could have told you that.....................sorry not to sound asslike, but i noticed that since the first day i bought my truck and it only happened when cold so pretty much assumed it was normal. and since plenty on here have described the same thing before, it should quit fluctuating after motor is warm.
but i understand the concern as some have shown before. but its makes sense since the oils viscosity is very high when the oil is cold.
CALMINI sucks!
  #24 (permalink)
Old 03-21-2008, 11:53 AM
UpFront's Avatar
I still want to know why my IMS gaskets broke down.
  #25 (permalink)
Old 03-21-2008, 12:50 PM
toyniss's Avatar
i want to know to.
really eager to see what brutal's looks like when he takes it off, obviously will have something to do with how soon i install mine.
CALMINI sucks!
  #26 (permalink)
Old 03-21-2008, 01:07 PM
UpFront's Avatar
Originally Posted by toyniss View Post
i want to know to.
Yeah, I think the "Honey Do" list took priority over the "Tinker with the Truck" list.
  #27 (permalink)
Old 03-28-2008, 08:26 AM
Fear Night's Avatar
First of all, it looks like a heat issue to me. However, I'm not sure why they would be affected since the stock gaskets have done fine with the same amount of heat.
It could also be some kind of abrasive that got in there. I know brake parts cleaner will eat through rubber and foam like nobodys business; it would wreck those gaskets. Did anybody clean your engine with a de-greaser? (car washes usually have this solvent) What about any oil getting sucked in by your air filter after a cleaning?
I find it highly unlikely that it was an over tightening issue. When tightened, the gaskets will tuck right up into the crevice without overlap. You would have to severely mess up putting in the gaskets for that to be an issue, and even then the damage wouldn't look like that.
Still pretty scary, I just installed my IMS yesterday afternoon.
2007 NISMO Frontier 4x4, KC, Black - K&N intake, 2in/2out custom Magnaflow duals, WRP IMS & TBS, Hypertech tuner, BFG AT KOs, 1 x JL 12W6v2, Tint
Check out my Frontier videos on YouTube
  #28 (permalink)
Old 03-28-2008, 01:15 PM
UpFront's Avatar
Nothing of that nature has ever come in contact with those gaskets while they have been in my hands, during install, or after. and I have a dry flow air filter. I am still waiting for someone else to check their gaskets to find out if there are any other problems. Will wants me to fork over 45 bucks for new ones, which aint gonna happen so I guess the IMS is now a big paperweight I never should have purchased. I'm not too stoked about the fact that the possibility of them just being bad from the get go is just being blown off. Like I said I am wondering if anybody else has this issue as well, but just doesn't know it.
  #29 (permalink)
Old 03-28-2008, 03:02 PM
CT_Nismo's Avatar
If you had over torqued the gaskets, they would have seen mechanical failure. Your pictures show a completely different failure mode. The failed gaskets looked smeared meaning there was chemical failure or thermal breakdown (i.e. melting). Gaskets designed for automotive use must endure the typicaly solvents found around cars. It is very unlikely that the gasket saw a solvent that caused it to fail. Melting seems to be the failure mode. The gaskets should be returned to the vendor who will also want to know what happened. Simple chemical analysis tests will uncover the truth.
06 Nismo 6M 4X4 Blue
  #30 (permalink)
Old 03-28-2008, 05:55 PM
UpFront's Avatar
Yeah, you can see some of the gaskets are melted due to heat. That makes me wonder... in the stock location on the intake plenum, or runner manifold, they are only in contact with metal on one side, but with the IMS installed they are sandwiched between two metals. Maybe the heat is too much for them. I contacted the vendor and he just seems to want me to pay for replacements, but I'm not about to fork over more money and have the same thing happen.
Closed Thread
