Idle Issue after TB cleaning - P0507 - Page 3 - Nissan Frontier / Navara Forum
  #21 (permalink)
Old 01-22-2012, 03:28 PM
MESOGLEA's Avatar
How about disconnecting the battery overnight?
I have a bored throttle body and have had none of these issue.
TB porting/boring?
throttle body screen/mesh removal
The modifications never end...........
San Diego Uprev
http://socalperformanceracing.com/
  #22 (permalink)
Old 01-22-2012, 05:01 PM
It is possible to damage the throttle blade control motor by moving the throttle blade (usually happens when you leave the ignition on while moving blade). Neither of the tps sensors or the throttle control motor at available separately, you must purchase the whole throttle chamber assey, and there will be a core charge. Its not common, but not unheard of to damage it.
As previously stated, its most likely a incomplete iavl relearn, but without the proper tools (consult 2 or 3) there is no way to know.
2011 FRONTIER SV 4X4 6SPD CC/LB Knight Armour
Lifted, truetrac, injen, ims, bullydog, skids, HID projectors, WRP underdrive crank pulley, blah, blah blah
  #23 (permalink)
Old 01-22-2012, 05:05 PM
JNR's Avatar
JNR JNR is offline
Hmm, that's too bad then if it did get damaged and interesting being able to damage the throttle blade motor...done this to several other cars that had DBW (no cable), but never did it with the ignition on though. Won't take a chance with this one then, as far as moving the TB blade by hand and going to try the method described above instead (using somebody to press the gas pedal). However, probably be some time until I end up doing it, as I only have 15k as of now.
Well, suppose he could try the relearn procedure first and hopefully there is no damage done, as that would suck!
  #24 (permalink)
Old 01-26-2012, 11:34 AM
Send a message via Skype™ to cyber.shifter
I've done the relearn many times now, with no success. I know there is a TSB on this issue so I think I'm going to bring it to the dealer and have them look at it. I have a service contract on the vehicle so it shouldn't cost me anything.
  #25 (permalink)
Old 04-13-2012, 04:03 PM
SKOLJACK's Avatar
I have regretably, cleaned my throttle body (chamber) and had the P0507 code set. Tried the relearn several times with no luck. Had a friend that works at the local Nissan dealer reset everything with a Consult II and it's all operating properly at this time! I bought the whole Service Dept. pizza for lunch. It was the least I could do!
CAUTION: This space reserved for nonsense!!!
  #26 (permalink)
Old 04-15-2012, 11:47 AM
i have a 04, my haynes manual says the throttle bottle (butterfly) has a coating on it and do not clean it ,i think all vechicles over time and mileage get carbon buid up on the butterfly, if any one that doesnot have carbon builup on it , take a picture, i would like to see it thanks
  #27 (permalink)
Old 01-19-2013, 12:41 PM
This may work...
Like it seems others I cleaned my throttle body without first checking to see if it was ok on the forums, and now I have the dreaded P0507 high idle code. I couldn't bring myself to even buy the $200 junk yard TB, so after some research on other vehicles I found this stuff:
Buy Dow Corning DC 321 MolyKote Dry Film Lubricant Spray - 11 Oz. Aerosol Can at SkyGeek.com
They apparently use it on Misu's for the same problem. Check out this thread.
throttle body plate sealant - evolutionm.net
I'm going to give it a try.
  #28 (permalink)
Old 03-25-2013, 01:28 AM
khmaiaznboi89's Avatar
I've also heard of guys using tomei throttle coat to solve the issue but if you want to clean the TB 3M has a cleaning kit that is "coated throttle safe" according to the lablel. I've cleaned my throttle with CRC a couple times before but it never threw i code i did it again at 90k and it has thrown a code.
edit: a post i found on mitsu http://forums.evolutionm.net/evo-eng...e-sealing.html
also i believe you can use Loctite Moly Dry Film
SILVER 05 Nismo Crew Cab
STILLEN High-Flow Intake, yellow fogs
PRG leveling kit
Goodyear Wrangler DuraTrac 286/75/r16
Softtopper soft top canopy
need new rear bumper
