I P D M - Nissan Frontier / Navara Forum
Old 03-05-2010, 05:35 PM
madmat's Avatar
I P D M
car died outside of the dealer today when i left,ran for about 1-2 mins got it started after 5 tries and went right back.said the ipdm is bad $430.00 to fix $100.00 to look at.well i looked on line and found it maybe the ecu relay.titan forums said panasonic partcmi-d-12v $2.69 has anyone else got experience with the ipdm. i would appreciate it.
Old 03-07-2010, 03:42 PM
madmat's Avatar
anyone got any info on this idpm thing?
Old 03-07-2010, 06:33 PM
Check on www.thenewx.org , I think I've read about what your talking about over there.
Old 03-07-2010, 11:06 PM
madmat's Avatar
ok thanks ill see what they have to say
Old 03-08-2010, 02:16 AM
You may want to try and find another 2nd gen and swap IPDM's with them. It's a very quick thing to do with no tools required. See if it works.
The relay can be found at napa/parts plus. Has a different model #, etc... when I was messing with relays, the guy let me go in the back of the store and just tear into all of the relay boxes in the warehouse, found one that looks identical, plugs right into the IPDM, perfect fit... I'd tell you the part # if I knew where it was now.
You may have a bad ECM, bad ECM can be caused by a bad ground in the coil-on-plug ignition wiring. Check your grounds on the top right of your engine towards the front. Probably covered by the plastic nissan cover. Check body grounded. Bolted to the left of the battery and the right of the air box.
ECM fried on me because of a bad ground on the ignition system, crappy deal. Nissan says it was my IPDM.. Ordered a used-known-good one, ... no start (no spark).
Changed the ECM, fired right up, ran kind of rough, found the bad ground on the engine explained above, fixed.
Your truck DOES start though, mine didn't.. at all, just turned over, so it's probably got to be a bad relay in the IPDM in your case.
05 Nismo Crew Cab @ 45K miles. It's got some mods.. [Pending sale]
07 Avalanche Xterra offroad, mods await.
See my custom computer audio infotainment system build here.
Old 03-08-2010, 05:53 AM
devious1's Avatar
Old 03-08-2010, 05:48 PM
madmat's Avatar
truck would not start at all today.if you run across the part# let me know.435 was totall. how much was the ecm?i found the relay at onlinecomponets.com part#cmi-d-12v 2.69 you have to spend $35 to make order.this info was found on a titan forum.
Old 03-08-2010, 06:00 PM
dubie2003's Avatar
Did you swap the relay from the Fog Lights to confirm it was a bad relay before dishing out any money?
07 SE CC Auto
Old 03-08-2010, 07:34 PM
madmat's Avatar
no not yet have the unit out and im going by what the titan forums said as far as the location of the relay(ecm relay2nd from left can you confirm?and fog relay 4th from left) this is on the bottom row with 4 relays.i think the titan and frontier IPDM is the same lay out as ares .dont want to fry anything
Old 03-08-2010, 08:31 PM
Zero Six LE's Avatar
Why do they (dealer) charge so much?
CONTROLLER UNIT-IPDM ENGINE ROOM - Frontier (D40) :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
