Not to jack the thread but this would include alot of people. Is it in the US or just Canada?
05 NISMO KC 4.0L DOHC 265HP V6, Mobil1 FS, 2W ABLS/Diff lk, V1 radar/laser locator HW, air box mod, Bridgestone Duelers A/T Revos, PIAA extremes, 3rd brake light mod, LE Body molding, tinted windows, 6 Speaker Pioneer AVIC-N4 custom fit In-dash DVD receiver/navigation system, SiriusXM satellite tuned. Last edited by Stormgray : 06-14-2008 at 12:04 AM. |
Interesting article on affect of tire size, gear ratios, and computers
I just found this article and thought this paragraph was relevant to the discusion:
One other point about changing gear ratios – in modern vehicles the computer that controls virtually everything has to have accurate road speed information. Vehicle speed information is typically generated at the transmission, which is “upstream” of the rear axle. Which means, of course, that changing the rear-axle ratio results in inaccurate speed information. This information plays an important part in controlling the fuel injection, the airbags, ABS, and speed display. If the rear-axle ratio is changed (or even if wheel/tire sizes are changed) the computer has to be updated for everything to function properly.This seems like a pretty good argument in favor of getting the inline speedo calibrator. This seems to confirm the theory that tire size change affects alot more then the speedo and could be costing you MPG.
further, well, nevermind that, we all know nissan can be stupid so yeah, they probably do base a lot of stuff on a parameter that cannot be adjusted to account for other changes (without aftermarket hacks that is)
I found the speedometer in my 08 to be reading about 3 mph or so fast. I just figured it was programmed with the NISMO tire size, 265/76/16's as opposed to the 267/70/16's. That could explain why the NISMOs seem to be more accurate.
Dan
2008 KC SE V6 4x4 Fog Lights and fog light mod, Cherrybomb Vortex muffler Lund Genesis Tri-Fold Tonneau, KV CAI |
As for the Nissan comment, I don't think this is a Nissan specific issue, other then perhaps the lack of aftermarket options, but I'm not sure we can blame them for that either. The fact is when you change your tire size you change your "final drive ratio" and there is no way for the computer to compensate for that unless you tell it, and I'd be surprised if any production vehicles give you the ability to do that without some form of aftermarket tool. Its also pretty clear that most (if not all) modern vehicles use that information to control fuel injection, manage shifting, airbags, abs, and a host of other things. So not adjusting for this change can have a negative impact on the vehicles operation. What is not clear to me is how much of an impact will it have and how much is bad. Clearly going from 31" to 33" is less of an impact then going from 31" to 35", but I'm not sure at what point we should be concerned and make a correction. It also seems clear that more important then getting the speedo right, is getting the gear ratio right. At some point we are increasing the gear ratio beyond the design specs of the drivetrain and that needs to be corrected by changing the pinion gear ratio of the rear end. It looks like we all (2nd gen) either have a C200K or M226 rear end. And within both of those variants there are multiple gear ratio combinitions. So swapping a C200K from a 6 cyl CC AT with that of a 4 cyl AT may give you the gears you need to compensate for the bigger tires. Ideally we could swap the gears without swapping the whole rear end, but I have not found that option for the C200K yet. This option is definitely possible on the M226 (Dana) rear end. What's interesting is bigger tires with deeper gears brings you back to the original "final drive ratio" and may elimiate the need for speedo recalibration.
It may be more of an issue with the computer not having accurate info on an auto but in a manual, the biggest issue I see is the ABS.
mine decision was purely speedo and odometer. my wheel/tires are slightly smaller and about 10lbs lighter (each) than the stock nismo combo...
Performance: WRP: CP/Grounding Kit/IMS/PS Pulley, AEM BF CAI, TB Grounding, TB Mesh Removal,TBS, E-Fans, Optima 35R,Nismo S-tune Exhaust, Nismo 18's on Nitto 404, TBIC, Nismo thermostat, UpRev Tuned ![]() Exterior: Roof Rails,Smoked Euro Tails,5k HIDs & Fogs,Fog Light Mod, Painted Engine Covers, Nismo Tailgate Badge, 20% Tint, Nismo Radiator & Reserve Caps, Nismo Oil Cap, Redline Tuning Hood Struts,Smoked 3rd light, EZdown, Color match head lights/grill/tailgate finisher, Custom Badging,Red calipers,door mouldings Interior: RF System, Nissan IPOD,Al pedals,Color Matched switch covers, Homelink, LEDs,custom shifter,HVAC Overlays,Auto down windows To Do: Custom Overlays, swaybar & more |
my 08 Nismo shows 80 on speedo when GPS shows 82. 60 on speedo when GPS shows 61.
Ryan 2008 CC Nismo 4x4 Mods: Alpine stereo, Cobra CB |
I wonder if they have the same speedo setup on all these vehicles regardless of tire size and gearing and that's why some are acurate, some are high, and some are low? I've got 30.5" tires stock and the NISMO had 32" (i think) looks like you could split the differance and have an acurate speedo.
My speedo vs. GPS(Garmin GPSMap 60CS) turned up results similar to above. Ranges from 3-4mph, down to 1-2mph faster.
2006 SE KC 4x4 auto ![]() |
