How to turn off the tire pressure sensor? - Nissan Frontier Forum
post #1 of 12 (permalink) Old 02-11-2012, 06:39 AM Thread Starter
06' frontier XE 4cyl 5speed
For some reason, whenever I turn my car on the tire pressure light blinks for a minute then turns on solid. Checked the psi of my tires (on multiple occasions) and it's at the recommended 35, I even tried to overfill the psi and the light still didn't go off.
At 35psi, i drove miles and miles to no avail. I give up on this tpm system. Is there any way to completely disable it?
Legend is offline
post #2 of 12 (permalink) Old 02-11-2012, 08:36 AM
bimmernut318's Avatar
electrical tape over the light would disable it, there are a couple of threads here for DIY "reprogramming" if you will. Search TPMS and you should find it
bimmernut318 is offline
post #3 of 12 (permalink) Old 02-11-2012, 11:19 AM
Mylt1's Avatar
Quoted: 2 Post(s)
fill them to 40PSI then go for a drive. make sure to get up to road speed for a few min. that should reset the light. then you can drop the pressure some.
05 LE CC 4X4. SUPER BLACK
Mylt1 is offline
post #4 of 12 (permalink) Old 02-11-2012, 11:50 AM
If the light is blinking then you have a bad sensor.
'06 Red Alert Frontier 4X4- Traded
antv20 is offline
post #5 of 12 (permalink) Old 02-11-2012, 12:27 PM
If the light is blinking, its means there had been an error in
the system and it has stored a code. Nine times out of ten, the sensors just need to be re-registered, but this means a trip to the dealer (they are the only ones with the tools to do it).
2011 FRONTIER SV 4X4 6SPD CC/LB Knight Armour
Lifted, truetrac, injen, ims, bullydog, skids, HID projectors, WRP underdrive crank pulley, blah, blah blah
speed demon is offline
post #6 of 12 (permalink) Old 02-11-2012, 12:56 PM
Mathster's Avatar
Quoted: 91 Post(s)
Or you have had the same sensor re-registered every couple months until they tell you that you need a new sensor.
13CC4x4SV
Mathster is offline
post #7 of 12 (permalink) Old 02-11-2012, 01:21 PM
BCBrian's Avatar
Quoted: 342 Post(s)
Reset procedure
I found this on the Discount Tire page.
TPMS Resetting Instructions
2015 Xterra PRO4X. Brilliant Silver. BCBrian's X build thread
Armor: Shrockworks front bumper. Hefty Fab 5 pc skidplate set. White Knuckle sliders. ARB differential cover.
Suspension: Front: Radflo 2.5" C/O's w/ 650 lb springs and PRG UCA's. Rear: Stock PRO4X Bilstein's w/ OME springs.
Wheels & Tires: Stock PRO4X alloys with LT285/75R16 Goodyear DuraTrac's.
Radio: Uniden Pro 520XL. Wilson Flex 4' antenna.
Got Questions? Help Us, Help You!
*WARNING* Clean your battery terminals!
BCBrian is offline
post #8 of 12 (permalink) Old 02-11-2012, 01:49 PM Thread Starter
How much does the dealerships usually call?
Legend is offline
post #9 of 12 (permalink) Old 02-11-2012, 02:00 PM
brett3116's Avatar
Quoted: 3 Post(s)
my TPMS light will not go off either. All tires are 35-36 psi. 68k miles and this has never happened before.
07 Frontier NISMO CC Avalanche, NISMO CAI, PRG 2 inch Leveling Kit, Wet Okole Seat Covers, 2* Timing Advance, WeatherTech Floor Liners and Bug Deflector, Bed Extender, Stainless Steel Nerf Bars, Chrome Window Switch Covers, WRP Grounding Kit
brett3116 is offline
post #10 of 12 (permalink) Old 02-11-2012, 02:32 PM
Depends on the dealer, just to register the sensors usually 20-45$. Call first and get a quote.
brett3116-if the light flashes when you first start the vehicle, there its a error in the system. If the light just comes on solid, you're pressure is off (see garbage pressure gauge).
