factory rack holds 125lbs. what does thule say about there racks?
05 LE CC 4X4. SUPER BLACK |
I think that thule says 150 lbs for weight on top. But Im worried about the air pushing up on the kayaks while driving on the highway. I dont know how much pulling those flare nuts can take. any suggestions?
i carried a light weight kayak & i have the thule traks installed and you will need to run a cord off the rear bumper & one at the front bumper to keep it from going up and down , not because the racks cant hold it (they can easy) its just to long to support on that short of a span , good luck
2006 CREW CAB - 6" LIFT CONSISTING OF CST 4" SPINDLE , TITAN SWAP, RADFLO'S W/ SILVER EIBACH SPRINGS ,2" CST REAR BLOCKS , REAR DEAVERS , KENWOOD TUNER W/SIRIUS SATELITE , GUN METAL POWDER COATED WHEELS , AIR BOX MOD / CUSTOM ROOF RACK (NOT FACTORY) 2006 GIANT XTC CARBON MTB / 2009 REDLINE CONQUEST PRO CYCLOCROSS BIKE Last edited by raceline : 02-13-2008 at 02:45 AM. Reason: forgot pic |
i've laid on top of my factory rack and i weigh 135 maybe more i think i gained weight
SILVER 05 Nismo Crew Cab (first owner on only 36k) + STILLEN High-Flow Intake + Yellow fogs + TBS need new rear bumper |
My other question is that people say that they installed a 54" thule track but I dont see that they make that size. Can I buy the next size up and chop it down to size?
Yea, you can cut Thule bars to any size you like. Mine are 52".
FWIW,I hauled yaks, canoes and aluminum boats regularly on my factory racks w "yakathule" bars last year. Many were big/heavy boats ( i.e 17'4"-120#). Hauling them upside down helps the find force push them down/into the racks vs lifting them. Also , I do use bow lines but only on boats longer than 14' and/or of flexible materials. ( I've hauled 14' aluminum boats on my Tacoma's roof racks for thousands of mile with no bow line at all.) I do use good rachet straps at the mid section of the boat though. Never had a problem. Having said that, I'll pass on a few tips I've learned over the years of "car topping" boats that make it easier. First, make yourself a set of nylon tie in loops to attach to your truck as follows: Get a couple of 16+/-" 1"wide nylon strapping pieces (like off the ends of those rachet straps) and double them over into a loop. Then, punch a matching hole in the ends ( a hot nail works good here) big enough to put a 1/4" bolt through. Now, go under your hood and find one of your forwardmost fender attaching bolts ( or a hole in the fender flange) on both sides of the engine compartment. Pull a fender bolt and reinstall it going through the doubled nylon first. (or install a new bolt and nut in a vacant hole to accomplish the) same. What you will end up with is a nylon loop that is now fixed to the fender. This loop can now be flipped in or out of the hood as needed, to provide a secure tie in point that keeps ropes off your hood, fender , etc. This ten cent fix works GREAT and disapears when you don't need it. If you want to go a step further, make a V or Y shaped bow line for your favorite boats and end them with (3) Carabinas. This allows you to quickly clip into those truck loops and the boat. It has the added benifit of putting your boat in the sme exact location on the racks every time AND iliminates chances for bad knots. hth ![]() ![]() ![]()
07 Frontier LE, 4x4, Crew Cab, Short Bed, Avalanche White. Mods: Access Lorado Tonneau, Raamat sound deadener, Custom Audio (JVC KW-GX700, XM, Ipod, Pioneer D702P, CDT HD-62, Infinity Ref, Alpine PDX4.100, Profile AP400 & PioneerTS-SW841D (front seat sub) Remote Start, Yakathule Racks, Wheel Locks, OEM All Season Mats, Silverstar Ultra Headlights, LED Back-ups, 13" Rubber Antenna, EZDown Gate Dampener, Light Buster hitch light. Last edited by WeeHooker : 02-13-2008 at 11:04 AM. |
| The Following User Says Thank You to WeeHooker For This Useful Post: | ||
EB_05_NISMO (02-13-2008) | ||
This is a sweet trick. |
thats a great idea, thanks. Im definetly going to use that. I just hope that the thule 'tracks' that are only attatched to the sheet metal of the roof with flare nuts hold up... Almost wish I had just got the LE with the factory rack so I didnt have to worry about it.
New tiedown pics added on request:
