How to get better gas mileage - Nissan Frontier Forum
 5Likes
post #1 of 41 (permalink) Old 04-21-2016, 10:04 AM Thread Starter
Quoted: 3 Post(s)
So, I'm about to go on a 4,900 mile road trip so I figured this would be a good time to do some better mpg modifications.
I have a stock 2006 Nissan Frontier 4.0L V6 4x4 with about 60,000 miles on it. I just went on a little trip and just set the cruise control for the speed limit (55 or 65) and the best I can get is 19mpg. It has a new air filter, new tires and the tire pressures are correct, so that's about it for now.
Does anyone have any hints on upgrades that will give me the best bang for my buck?
sminthian is offline
post #2 of 41 (permalink) Old 04-21-2016, 10:16 AM
Quoted: 24 Post(s)
Keep acceleration RPM under 2000. Cruising RPM at or below 2500. Coast to slow down instead of braking.
dpal is offline
post #3 of 41 (permalink) Old 04-21-2016, 10:51 AM
AndysLog's Avatar
Quoted: 855 Post(s)
Feedback Score: 9 reviews
so i heard those new prius cars are doing well.
Blue Devil and Justwork like this.
AndysLog is offline
post #4 of 41 (permalink) Old 04-21-2016, 11:33 AM
Quoted: 7 Post(s)
Lighter tires (p instead of Lt) helps.
For mine, I get about 21.5 mpg highway at 75mph. 2015 cc lb. I've recently aired up my tires to 38psig and changed my air filter to an aem, so well we'll see if those have any effect this summer.
rubber314chicken is offline
post #5 of 41 (permalink) Old 04-21-2016, 11:55 AM
shizzy's Avatar
Quoted: 960 Post(s)
With gas around $2 gallon, there are no "bang for the buck" things out there. The comfort and cargo capacity my truck gives me far out weighs the MPG's it gets. My Dad and I can load up two guy's worth of a weeks worth of hunting gear, still have plenty of room to sit and drive 5 hours without feeling cramped. So I get 17mpg. oh well.
racquetballer likes this.
The other Sean,
2011 Pro-4X CC
Overland bound #2292
See my 2011 Pro-4x build here
shizzy is offline
post #6 of 41 (permalink) Old 04-21-2016, 02:31 PM
ratman6161's Avatar
Quoted: 102 Post(s)
Agree there are no bang for the buck mods to be had and even if we were looking at $3 or $4 gas, the same would probably be true.
Might be aerodynamics of a brick but my truck drops off on MPG anytime I'm cruising above 65 MPH. For my old job where 2/3 of the miles back and forth to work were on country two lanes with the cruise set on 60 - 65 I would regularly get 20 to 21 MPG except in the winter. At my new job where its the same distance but much more interstate driving at around 75, its dropped off to 18 - 19 MPG.
But here is the best way to improve mileage: Wait until there is a strong tailwind headed in the direction you want to go. A couple of summers ago, I drove from Buffalo, MN to Madison WI (mostly cruising down I94) and got over 24 MPG using this method.
2013 SV-V6 W/VTP
ratman6161 is offline
post #7 of 41 (permalink) Old 04-21-2016, 02:46 PM
raine's Avatar
Quoted: 645 Post(s)
40-psi
- Raine.
Girls Girls Girls!
Do not click above.
TYPE CREW CAB SV 4x4 VTP COLOR NIGHT ARMOR LIFT 3.5"/2.5" NAME KEIRA
SUSP: Custom King Shocks . Total Chaos . Level-8 . Deaver . Nisstec . Bilstein . PRG . BF Goodrich
EXT: Rigid Industries . P&P . PIAA . White Knuckle . White Rhino . Truxedo . Firestik . BlueSea
A/V: DNX-892 . TWK-88 . PDX-V9 . HSK-165XL . DCX-165.3 . 2x 10TW1-4 . Dynamat . 2x Cameras
MODS: Reservoir Mounts . Power Tailgate Lock . Custom CB Antenna Mount . Trailer Plug Relocate
MORE: Midland . UltraGauge . Raingler . Working OEM SWC, Bluetooth, USB . Some Cool Stickers
raine is offline
post #8 of 41 (permalink) Old 04-21-2016, 08:44 PM
upflying's Avatar
Quoted: 210 Post(s)
Drive like there is a raw egg between your foot and the skinny pedal.
If you like feeling power, apply elsewhere.
Squeeze the throttle instead of pushing it. Coast up to red lights.
Power is gas.
upflying is offline
post #9 of 41 (permalink) Old 04-21-2016, 10:01 PM
The_Pope's Avatar
Buy a 2016 model. Mine gets 22 at those speeds. And I'm 4x4. Color me happy.
2016 Fronty SV 4x4 CC with truck value pak and trailer tow
The_Pope is offline
post #10 of 41 (permalink) Old 04-21-2016, 10:32 PM
shizzy's Avatar
Quoted: 960 Post(s)
yes! Spend tens of thousands to get 3 MPG!!
Dale Barnard and Dale Barnard like this.
The other Sean,
2011 Pro-4X CC
shizzy is offline
The Following User Says Thank You to shizzy For This Useful Post:
Zero Six LE (04-24-2016)
