Help Me Find The Oil Pressure Sensor/Switch - Nissan Frontier Forum
post #1 of 17 (permalink) Old 12-29-2011, 08:03 PM Thread Starter
stagolee's Avatar
Vehicle: 2006 Nissan Frontier, LE 4x4, Crew Cab
The oil pressure gauge on my vehicle has been spiked at "High" for the past two days.
I've read around the site and learned some troubleshooting tips and possible remedies.
I've changed the oil (5w30 Mobil 1) and filter (OEM) but that did not affect the gauge.
So, now I'm onto changing the Switch. I purchased Nissan Part #25240-4M40E and am now trying to figure out where it goes.
Link to part: http://www.courtesyparts.com/25240-s...-p-612822.html
I've located what I THINK is the right spot on the truck to plug it in, but the current item there doesn't look like the part I purchased.
Please review the photos and verify whether I'm looking in the right place for the sensor or switch.
I understand that the '05 model had a real Sensor, and the '06+ have a Switch.
Is it possible that (despite conventional wisdom), I actually have a real Sensor and not the Switch that folks here like to call the "dummy gauge"? My vehicle was manufactured in 04/2006.
Thanks.
This is what I THINK is the Oil Pressure Sensor.
Same sensor, different angle.
Same sensor, again. Unplugged.
UPDATE: I looked up the Sensor (Part #: 25070-CD00A) and found this - http://www.courtesyparts.com/switch-oi-p-605884.html which looks a LOT like the object in my photos.
I now strongly suspect that my vehicle has the Sensor and not the switch. However, I would still like visual confirmation from you folks here that I'm looking in the right place.
Thanks.
2006 Frontier LE CC 4x4 - Storm Grey | Volant CAI | *** GONE! ***
Last edited by stagolee; 12-29-2011 at 08:14 PM. Reason: Added updated information re: Sensor.
stagolee is offline
The Following User Says Thank You to stagolee For This Useful Post:
Dave Faust Jr. (01-09-2015)
post #2 of 17 (permalink) Old 12-30-2011, 09:32 AM
characterzero's Avatar
subscribed
My truck has been pinned at H for almost a year, and I am looking to do this as well. I have an 05, so the real sensor too.
Keep us posted on how it goes, hopefully someone here can chime in.
2005 Frontier CC Nismo 4x4
Exterior: 20% tint, ARE Topper
Performance: NISMO CAI
Suspension: Radflo 2" front, Bils5125 rear with Calmini 1.5" Shackles, Deaver AAL, 285/75 GY Duratrac
Electronics: skipped the HU, audio in to Alpine ERE G180 Equalizer, JL A4300, Alpine MRP 350, Infinity Kappa 60.7cs and 62.7i, JL Stealthbox
characterzero is offline
post #3 of 17 (permalink) Old 12-30-2011, 09:39 AM
Krillz's Avatar
I think it on the upperside of the oil pan, around the corner from the filter. Passenger side
Krillz is offline
The Following User Says Thank You to Krillz For This Useful Post:
stagolee (12-30-2011)
post #4 of 17 (permalink) Old 12-30-2011, 11:18 AM
That is the oil pressure sensor.
2011 FRONTIER SV 4X4 6SPD CC/LB Knight Armour
Lifted, truetrac, injen, ims, bullydog, skids, HID projectors, WRP underdrive crank pulley, blah, blah blah
speed demon is offline
The Following User Says Thank You to speed demon For This Useful Post:
post #5 of 17 (permalink) Old 12-30-2011, 12:51 PM
You got it.
disallow is offline
The Following User Says Thank You to disallow For This Useful Post:
post #6 of 17 (permalink) Old 12-30-2011, 01:34 PM
switch vs. sensor
great, I've got the sensor and the cost is 70 vs 16...
post #7 of 17 (permalink) Old 12-30-2011, 03:48 PM Thread Starter
stagolee's Avatar
Sweet! Thanks folks!
stagolee is offline
post #8 of 17 (permalink) Old 12-31-2011, 12:17 AM Thread Starter
stagolee's Avatar
The job is complete.
The only tools I used were a 15/16 open/closed flat wrench and a light. NOTE: I suspect a 24mm tool would also work, but I don't have one of those.
The old sensor came right out, brought a little bit of oil with it. Maybe 1/4 cup if that.
The new sensor went right in.
I started up the truck and the sensor showed a valid reading.
It was, perhaps, a 15 minute job, excluding lifting the truck and time for the oil to cool.
The longest part of the job was gettin the old Sensor out of the tight space.
An adjustable wrench won't fit, and getting a deep socket around the sensor would take some acrobatics. It _may_ be possible, but I can't say for sure.
stagolee is offline
The Following 2 Users Say Thank You to stagolee For This Useful Post:
FitzIngarage (05-23-2012), frontin40 (12-31-2011)
post #9 of 17 (permalink) Old 12-31-2011, 12:35 AM
frontin40's Avatar
Quoted: 5 Post(s)
Mine has been pegged for 6 months now.
2005 CC 2wd auto
5" Calmini lift
15x12.5 Arctic Truck Prime Wheels
35x12.5x15 BFG A/T tires
Arctic Truck fender Flares
Superchips Flashpaq
frontin40 is offline
post #10 of 17 (permalink) Old 01-18-2012, 10:34 PM
zcrobins's Avatar
I will be installing my new sensor soon. One question what, if any; type of sealant is recommended to use on the threads while installing the sensor. I want to make sure I don't end up with an oil leak. You know the classic DIY fix one problem, create another. Thanks for any advice.
2005 Frontier Nismo--PRG 2" Level Kit w/ 1" Rear Block, Moto Metal 951's, Nitto Terra Grappler 275/65/18, PIAA Xtreme White Plus Lamps and Fogs, BakFlip HD Tonneau, Amsoil Filters and Lube
zcrobins is offline
