Old 04-29-2008, 11:15 PM
Help Identifying an Odd Sound...
Hey everyone, I have a sound that is worrying me. I have a 2005 CC, 6 speed manual, 4.0L V6 with 33400 Miles. Recently I have heard a "twitering" or chirping sound when coasting or decelerating, clutch out. At first I thought it was brakes, but then noticed the correlation with the clutch and now worry it might be drivetrain. Anyone else had this or suggestions on what to start checking?
Old 04-29-2008, 11:24 PM
CT_Nismo's Avatar
Rut Rho!
It sounds like the throwout bearing is making noise. I take it that when under load, there is no sound?
You are still in warranty. You may want to bring it into the stealership.
06 Nismo 6M 4X4 Blue
Old 04-29-2008, 11:42 PM
Correct, when there is load there is no sound, it is only when there is no load that I hear it. Stealership here I come. Great.
Old 04-30-2008, 12:46 AM
Might also be worth looking @ the u-joints. Does it sound anything like a squeaky spring going really fast? Check your drive shaft for excessive play.
Old 04-30-2008, 09:07 PM
Yeah it sounds like that too...
Old 05-01-2008, 05:47 AM
06nismoKC's Avatar
2 }{ on the u joints.
Old 05-13-2008, 01:02 PM
Update:
so I am just back from the dealer. quote: "we've never really seen anything like this...". Apparently the Driveshaft is faulty somehow. Also, the driveshaft is somehow different from all the other frontys because it is a 6 spd CC. So they have ordered it and it will arrive in 3-6 WEEKS! Until then, they have told me to drive it as normal. Geez. Only good thing is that it is completely warranty.
Old 05-13-2008, 05:08 PM
Glad to hear you figured out the issue.
