Heater blowing cool air. - Nissan Frontier Forum
post #1 of 25 (permalink) Old 12-07-2009, 07:09 PM Thread Starter
Hi folks,
I just noticed that my heater is blowing cool air. It just started happening this week. The temp gage isn't too hot or cold it just blows cold air. I don't have any coolant leaks and have also noticed that if I rev the engine to about 4 RPM's it blows hot...just like the good ol' days. You think it's the thermostat or something else? It's a 2006 Nismo.
-Thanks,
-TJ
tjcolda is offline
post #2 of 25 (permalink) Old 12-07-2009, 07:28 PM
Clint's Avatar
Quoted: 338 Post(s)
I believe your thermostat is stuck open.
Clint is offline
post #3 of 25 (permalink) Old 12-07-2009, 07:30 PM
chaz's Avatar
mine does the same thing 06 cc,it takes a little while to get warm,mostly when things are really flowing like driving on the road,then it gets hot,just at idle not very warm.
chaz is offline
post #4 of 25 (permalink) Old 12-07-2009, 08:57 PM
Mathster's Avatar
Quoted: 94 Post(s)
Originally Posted by tjcolda View Post
Hi folks,
-Thanks,
-TJ
check your coolant level in the radiator on a cool engine. I bet your low.
My 00 does that, but mine likes to puke sometime each night and after a month or so, it will get a little low.
The only time I have seen the temp rise above normal was letting my son drive around an industrial park to get some practice.
13CC4x4SV
Mathster is offline
post #5 of 25 (permalink) Old 12-07-2009, 09:03 PM
Yup, check your antifreeze. Bet it's low. Mine does the same thing, just started recently. I've been having to add about 1/2 gallon every two weeks or so. I have no idea where it's going. No leaks that I can see, and I'm pretty sure it's not burning it. Any ideas out there?
Vootie is offline
post #6 of 25 (permalink) Old 12-07-2009, 09:33 PM
tperkins's Avatar
hopefully not the transmission
2.5" extended radflos, Deaver AAL, PRG adjustable shackles, 2 inch BL, Bilstien 5150's, trail gear sliders, flowmaster 50 series, new y pipe, air box mod with k&n filter, BFG at ko 285/75r16's, Pro Comp wheels,leer r100
tperkins is offline
post #7 of 25 (permalink) Old 12-07-2009, 09:39 PM
Zero Six LE's Avatar
Quoted: 832 Post(s)
Surely sounds like air in the cooling system.
Zero Six LE is online now
post #8 of 25 (permalink) Old 12-07-2009, 09:41 PM
Mine's a six speed, so I'm pretty sure that's not where it's going.
Vootie is offline
post #9 of 25 (permalink) Old 12-07-2009, 09:46 PM
Mathster's Avatar
Quoted: 94 Post(s)
like I said, mine pukes. its not a consistent leak the truck doesn't leak at work, just at home and just overnight..
If you have a gen1. it could also be a head gasket leaking into one of the cylinders.
13CC4x4SV
Mathster is offline
post #10 of 25 (permalink) Old 12-07-2009, 09:52 PM
Mine's a gen 2, '06 Se. I've parked in my garage overnight a couple times to see if there was any spillage, but none to report. I do smell antifreeze occasionally after I shut the engine off in the front of the truck. My guess is it's leaking a bit near the header and burning off.
Vootie is offline
