Don't you just love it when it's a simple thing that just need lube!
For anybody fixing this problem I'd check the hood latch before the bumpstops. And "real" grease that comes in a tub is alot better than the spray on stuff. Be very generous with the grease when applying. Put some in the actual latch (all over it). Then put a very generous amount on the latch "loop" (the part that's on the hood). You can usually see where the paint has rubbed off on the loop causing metal to metal contact. Once you do all that the problem should be solved! If not, do the bumpstops too!
06' NISMO FRONTIER 4X4 ![]() |
CALMINI sucks! ![]() ![]() ![]() |
![]() 2005 Frontier CC SE, PRG 2" Front Spacers, AC AAL 3" Rear Springs, Rancho RS5000 Shocks, 265/75R16 Radial SXT Mud Terrain, ARE Cap, Yakima Racks (Cab and Canopy). |
