Old 12-29-2007, 02:12 PM
Autospirit's Avatar
Got a squeaky front end?
This happened to me at around 4500 miles (with our first snowfall...any relation, I don't know) it was squeaking baaad. The front end would make noise on the slightest imperfection in the road. It first came from the right front, I checked the suspension and sway bar bolts which were all fine. Then after a few days the squeak moved over to the left side which led me to think that this could be body related.
A search of the CF database suggested lubing the hood bumpstops...which made sense. My frontier is now silent again.
Just thought I would share for anyone else because it seems like these rubber stops have given a few people a hard time. This saved me from going to the dealer and watching them chase their tails looking for a suspension problem.
07SECCSB4X
Old 12-29-2007, 02:15 PM
toyniss's Avatar
my hood latch/rubber stops squeek so bad im ready to ****ing drive my truck into a wall and get a new one....................but i cant really say **** about it to the dealer cause ive been rearended at the same time hitting another Xwith tow package in front of me ****ing up the front end so that may be the cause to.
CALMINI sucks!
Old 12-29-2007, 02:24 PM
Autospirit's Avatar
I used a spray lithium grease on the "threads" of the stops. The squeaking didn't go away right at first but gradually after a few days.
I'm sure youve tried everything, but don't be stingy with the lube.
07SECCSB4X
Old 12-29-2007, 02:35 PM
toyniss's Avatar
i actually cleaned my hood latch once and the noise went away until i was in the dirt again, then came right back---------so not sure if its the actual latch or the rubber stops, but i think its the latch-ill try the rubber stop thing with lube.
CALMINI sucks!
Old 12-29-2007, 02:54 PM
YES!
What are the hood bumpstops and where are they located?
Does WD-40 do the trick?
Old 12-29-2007, 03:46 PM
Sweet! I've been trying to find out what the hell that's been. Thanks!
05 Crewcab 4x4 w/ 8k hids and custom foglights
Old 12-29-2007, 04:37 PM
DeathByStereo's Avatar
haha, yeah my truck has done that since like 2 weeks after I bought it... I've lubed it several times actually... fixes it for a while... another thing, when it's squeaky like that, if you open then close your hood it usually goes away for the rest of the day/week then comes back...
2006 Super Black NISMO CC 4x2
Lift: 4" CST spindles, PRG adjustable shackle, Extended front brake lines
Performance: Volant Cold Air Intake
Exterior: 9 inch black stubbie antenna, Black Carriage works billet grille, borla SS muffler, sweet stickers
Interior: Avic f-90BT, MTX powered Subwoofer enclosure, Alpine speakers. Red L.E.D. dome lights, pathfinder switch covers, bling bling interior lights.
PS3 GamerTag - Death_By_Stereo
Old 12-29-2007, 04:39 PM
toyniss's Avatar
i actually know mine is the hoodlatch and possibly the rubber stops to, cause if i leave my hood open and shake my truck the noise doesnt happen.
CALMINI sucks!
Old 12-29-2007, 05:12 PM
PatMan's Avatar
If the rubber stops don't ..ahem, stop squeaking, try super-gluing a small piece of felt to the bottom of the rubber stops. Just a dime sized piece should do the job, exactly the same diameter as the contact surface of the rubber stop itself. This should prevent any further noise. I was about to do it with mine, but turning the bump-stop out a couple turns seems to have cured it all.
Old 12-29-2007, 06:05 PM
Well this came at a perfect time. Mine just started squeaking the other day and was going to go hunting for it. I'll have to give the hood bump stops a look. Thanks!
