Gas spilling out of filler neck when fueling - Nissan Frontier Forum
post #1 of 73 (permalink) Old 10-23-2010, 12:32 AM Thread Starter
06 Nismo King Cab, gas has started coming out of filler neck when filling, even at moderate filling rate. Have to fill REAL slow, which is a pain. Have used different gas stations, so it's not the pumps at the station. I'm thinking maybe an obstruction in the vent tube...anyone have similar problem?
jerryd67 is offline
post #2 of 73 (permalink) Old 10-23-2010, 01:04 AM
rocket's Avatar
dont know if this is the same problem but i used to have a similar problem. the pump would shut off automatically after just starting to pump gas. i dont put the gas pump handle in all the way. something about the angle of the handle doesnt seem to be the same as the filler tube.
Of course I can make it... I got a locker.
Shrockworks skids, PRG UCA's, Radflo coil overs (removed), Fox shocks coil overs w/ custom 1" spacer, Alcon leafs, Bilstien 5100's, painted stock headlights, Xoskel lopro light bar w/PIAA 510, Calmini Pre-runner bumper with custom steel front skid plate, Volant CAI, deleted Y pipe with Flowmaster muffler on stock exhaust, 285 Hankook MT on stock rims, 3.73 gears in rear (waiting on $$$ for M205 parts).
rocket is offline
post #3 of 73 (permalink) Old 10-23-2010, 09:30 AM
You could have a plugged breather valve, its off the the side of the fuel tank.
nissanmadness is offline
post #4 of 73 (permalink) Old 10-23-2010, 03:06 PM
ATLtoCO Frontier's Avatar
My '09 with 32k miles on it just started doing this. I need to take it in to get it fixed under warranty. That, and that incessant squeak that i can't figure out.
ATLtoCO Frontier is offline
post #5 of 73 (permalink) Old 10-23-2010, 04:59 PM
cranesrule's Avatar
My 2010 does this as well. Not only does the pump shut off, but it pukes fuel out of the filler neck as well. I have to fuel up very slowly, and keep the nozzle pulled out part way to keep it from happening. I bought the truck with 3100 miles on it and it has done it from the start.
2010 Frontier Pro-4x Crew Cab 4x4 Avalanche White
Leather, Moonroof, Rockford Fosgate, Nissan Side Steps, AVS Window Visors, Nissan Hood Protector, OEM Navigation Dock with Garmin Nuvi 750, Gentex Mirror w/ Compass and Temp, Pathfinder Switch Covers, LE Body Side Moldings, Firestone Destination A/T P265/75R16, AMI Stainless Stubbie, Flowmaster 70 Series, Access LiteRider Tonneau Cover
2010 Maxima SV Winter Frost Pearl
cranesrule is offline
post #6 of 73 (permalink) Old 10-23-2010, 07:28 PM
CoastGuardZ's Avatar
Quoted: 2 Post(s)
Feedback Score: 4 reviews
From the FSM...
SYMPTOM: CANNOT REFUEL/FUEL ODOR FROM THE FUEL FILLER OPENING IS STRONG
WHILE REFUELING.
-1. CHECK EVAP CANISTER
1. Remove EVAP canister with EVAP canister vent control valve and EVAP control system pressure sensor
attached.
2. Weigh the EVAP canister with EVAP canister vent control valve and EVAP control system pressure sensor
attached.
The weight should be less than 2.0 kg (4.4 lb).
OK or NG
OK >> GO TO 2.
NG >> GO TO 3.
-2. CHECK IF EVAP CANISTER SATURATED WITH WATER
Does water drain from the EVAP canister?
Yes or No
Yes >> GO TO 3.
No >> GO TO 5.
-3. REPLACE EVAP CANISTER
Replace EVAP canister with a new one.
>> GO TO 4.
-4. DETECT MALFUNCTIONING PART
Check the EVAP hose between EVAP canister and vehicle frame for clogging or poor connection.
>> Repair or replace EVAP hose.
-5. CHECK VENT HOSES AND VENT TUBES
Check hoses and tubes between EVAP canister and refueling control valve for clogging, kink, looseness and
improper connection.
OK or NG
OK >> GO TO 6.
NG >> Repair or replace hoses and tubes.
-6. CHECK FILLER NECK TUBE
Check recirculation line for clogging, dents and cracks.
OK or NG
OK >> GO TO 7.
NG >> Replace filler neck tube.
-7. CHECK REFUELING EVAP VAPOR CUT VALVE
Refer to EC-659, "Component Inspection" .
OK or NG
OK >> GO TO 8.
NG >> Replace refueling EVAP vapor cut valve with fuel tank.
-8. CHECK FUEL FILLER TUBE
Check filler neck tube and hose connected to the fuel tank for clogging, dents and cracks.
OK or NG
OK >> GO TO 9.
NG >> Replace fuel filler tube.
-9. CHECK ONE-WAY FUEL VALVE-I
Check one-way valve for clogging.
OK or NG
OK >> GO TO 10.
NG >> Repair or replace one-way fuel valve with fuel tank.
-10. CHECK ONE-WAY FUEL VALVE-II
1. Make sure that fuel is drained from the tank.
2. Remove fuel filler tube and hose.
3. Check one-way fuel valve for operation as follows.
When a stick is inserted, the valve should open, when removing
stick it should close.
Do not drop any material into the tank.
OK or NG
OK >> INSPECTION END
NG >> Replace fuel filler tube or replace one-way fuel valve
with fuel tank.
I can upload these pages if you'd like.
Good Luck!
-Nate
2007 CC LB SE 4x4 6spd: PRG 2.0 Radflos and Bilstein 5125's w/ OME Dakar Leaf Pack - Firestone Ride-Rites - Griffin Aluminum Radiator - Centerforce II Clutch - Gibson S/S Exhaust - Tekonsha P3 Electric Brake Controller - Pioneer AVIC F90BT - Soundstream Components and 3 Ways - Extang Fulltilt Tonneau - OEM Roof Rack - Bridgestone Revo2's LT265/75R16's - 2010 SE Wheels - AC Extended Brake Lines - Heated Mirror Mod - Tint - 129,000 miles
CoastGuardZ is offline
The Following User Says Thank You to CoastGuardZ For This Useful Post:
SDMF_Reaps (07-22-2013)
post #7 of 73 (permalink) Old 10-23-2010, 09:40 PM
FrontyPRO4X's Avatar
My 09 has the same problem. I don't know how many times ive had to grab paper towels and some of that window washing fluid to clean up the side of my truck. Really ticks me off.
09 CC 4X4 PRO4X / DT Catback / Shrock Rear Bumper
FrontyPRO4X is offline
post #8 of 73 (permalink) Old 10-23-2010, 10:05 PM
cranesrule's Avatar
Based on the number of people I have seen that are having the same issue, this seems to be a problem inherent in the design of the filler neck itself rather that a malfunction of any particular part. I will probably have the dealer take a look at it anyway. Definitely sucks getting gas down the side of your truck...
post #9 of 73 (permalink) Old 10-23-2010, 10:16 PM
Quoted: 2 Post(s)
Maybe it's just a short bed issue?
3.5 years - Almost 54,000 miles - Gas stations all over the East Coast from New Hampshire to Florida and not once have I had this problem.
Check w/ the Dealership.
post #10 of 73 (permalink) Old 10-23-2010, 11:21 PM
CDs4x4's Avatar
Quoted: 17 Post(s)
Feedback Score: 7 reviews
I had this problem dealer replaced the hole gas tank.
2007 Nissan Frontier LE 4x4 Super Black
CDs4x4 is offline
