Gas Gauge not reading correctly
Hey guys, Has anyone had a problem with their gas gauge not reading right? Mine has always been a little off. but the other day I add a TBS and cut out the screen. Since the needle has moved really fast. I filled up and only needed 4 gals with the needle at half a tank. Any ideas???
My last few fill ups my gauge has been off as well. Fill up and it says 3/4 of a tank. I'm going to call the dealership to see whats up.
After a fill up, I drive about 50 miles and its a 3/4, the bottom end says I am empty and I have about 5 gal. left. I guess it is best to more in the bottom than run out of gas, but it just doesn't seem all that accurate to me.
06 nismo, White, Stock mostly, retrax bed cover custom pipe rack. I thought I had purchased JUST what I wanted...UNTIL I CAME TO CLUBFRONTIER. |
07 KC SE in Storm Grey. Weathertech VentVisors, 15% tint, Cst Spindles, Radflos, Bilstein 5125, SS brake lines, PRG shackles, Flowmaster 40, 6500k HID, Volant CAI, 285/75/16 TG's w/ 7089's.
There is a TSB out about an erratic fuel gague. If you take it to the dealer and explain whats happening the will most likely replace the fuel gague sending unit.
I went to the dealer today for my oil change and they say that the gas messes with the sending unit causing it to read wrong. I just always set my trip meter and from the time the light comes on if I let it go that far, I have 4 gals. But yes the dealer offered to replace it and said it would probably do it again until they figure out how to fix the sending unit inself.
Taking mine in on Mon. to have the stealership look at it.
| Thread Tools | |
| Display Modes | |
