Old 05-10-2008, 02:06 PM
Slilock's Avatar
Send a message via AIM to Slilock
Fluid Change Cost
How much did it cost you for a automatic transmission fluid flush/change, brake fluid change, rear end fluid change? Also how old was your truck and how many miles did you have when you did it?
2006 Storm Grey 4X4 NISMO - Stock
Old 05-10-2008, 04:39 PM
tran flush and fill,112 dollars at nissan dealer. at 36000 miles
Old 05-10-2008, 04:49 PM
05cc4x4's Avatar
I just did mine today. I did the front and rear dif (3 qts royal purple) at about $30.00 I also did the transfer case (2 1/8 qts Valvoline dexron at like $12 total, Then the engine (5.5 qts of Q synthetic) at I think $30.00 . I had to buy a hex key for the rear diff, the upper one is 14mm, I have a C200. Not counting that and the permatex sealer, shop towels hand cleaner and stuff it was around $72 doing those myself. I also did the oil and rear dif on my pathfinder. I'm going to have the transmission on the pathf done at the dealer though. Especially if it's only $112 like the post above, it has 47k on it. My fluids looked pretty good although there was a bunch of metal on the drain plug and in the fluid itself. My frontier only has 27k on it.
White 05 LE crew cab 4x4. Mods so far- Rollbak bed cover, custom Yakima bike rack, Pathfinder center console, Pathfinder window trim, steering wheel audio controls added, vent visors and window tint.
Old 05-10-2008, 08:14 PM
Zero Six LE's Avatar
It's closer to $200 at my dealer for a transmission flush. The fluid alone is close to $100. They use BG Universal synthetic ATF. I haven't had a transmission flush yet though. I changed my own differential oil and will replace my brake fluid in July. I curently have just over 20,000 miles on the truck.
02 Maxima SE Tungsten Blue
Old 05-12-2008, 05:53 PM
Question Fluid?
What is "BG" Universal ATF?
Old 05-12-2008, 06:55 PM
Behold
BG Products, Inc.
Old 05-12-2008, 06:58 PM
wow i wish i had got that..my dealer said they only use nissan jmatic
Old 05-12-2008, 10:58 PM
Bg
Thanks for the link Zero. I had never heard of BG products. I did a search for a shop in my area and the results were a Toyota dealer, a Chevy dealer, a Ford dealer and 2 Chrysler dealerships. Must be good stuff, do ya think?????
Old 05-13-2008, 11:39 AM
You're welcome. My favorite Nissan tech (Frontier2) told me they use it in Titans and he also uses it in his Frontier. I would say that it's a good product based on that and others BG products I have used.
