I use Amsoil synthitic in the weight recommended by the manual. Mobile 1 is good as well. The two best in my opinion. I change mine every 7500 miles, oil and filter. This is what my dealer told me I could max out at with the synthetic without hurting my warranty. 5K should be no problem either, though if it were mine I would take it out to 7500 miles. I have a local friend who is a mechanic and Amsoil dealer do mine for me. I have no idea how much it would be if you just bought the Amsoil from a dealer or off the website. Anyway, good luck and enjoy the Fronty...
For over a thousand generations, the Jedi Knights were the guardians of peace and justice in the Old Republic. Before the dark times, before the Empire. _________________ 2005 Nismo CC 4x4, Valley Hitch, Alpine Headunit w/ Aux input for iPod |
1st answer: i like to use mobil 1 or castrol. as for intervals, i like to change the oil every 5000 miles. thats because i drive around a lot and if i wait for 3 months before the next one, i'll probably end up running 8 or 9,000 between intervals.
2nd answer: on our xterra i pay the dealer 10 to change the oil with regular nissan 10w30 oil and filter. it was some kind of deal we got when we bought it. as for the measurement isn't 3/8 like hald of 1/4 and 1/2? thats what i always thought it was. if you're doing it yourself, why not put 5 1/4 and then see if the truck needs more? 3rd answer: i don't know about this one but if i was in your shoes i would definitely just go for dyno oil and filter change every 5,000 since you use it alot. my question is, how are you gonna change the filter every 5ks when you're replacing the oil every 10? you must be really fast, otherwise oil will start flowing out of the filter hole.......
just as confused as you are ![]() |
i'm using amsoil right now and i'd say i swear by it. i noticed an immediate increase in how fast the motor will rev, it seemed to "free" up some low end torque. i've had mine in for over 5k miles now and it still looks brand new! i defintealy recommend it. my mom's altima is running mobil 1. it started running synthetic at 30k miles and we ran it till about 40k. the oil was still clean when i drained it but i knew it probably needed to because of how long it had been in there. it's almost up to 50k miles so it's getting that time again... hope this helps. basically, you can't go wrong with either brand although i read an article in Import Tuner and they tested a bunch of different synthetics and they recommended amsoil hands down because they ran it for 25k miles in a car and it was still brown (not black). the others only lasted around 10k miles. oh and you need 5W-30 if i remember correct for my truck...
p.s. amsoil makes a 25k miles oil filter too, to match their oil so if you used the amsoil products, you could probably safely get 10k miles out of both your oil and filter. that's my plan once i'm out of warranty. also keep in mind our bumper to bumper is 3 yr/36k miles, but our powertrain warranty is 6/60k miles.
Patrick 06 KC Nismosis 6 spd Storm Grey Mods: lots... http://www.myspace.com/15504802 Last edited by HKYStormFront : 10-19-2006 at 10:03 AM. |
umm... No it will not.
Oil changes by the manual are every 7,500 miles. As long as you don't exceed it, it doesn't matter what oil you use as long as the viscosity is what the manufacturer says it should be. Personally I do mine every 5,000 miles and rotate tires at 10,000 mile intervals. It's easy to remember that way. I looked at the oil filter location and it looked extremely difficult to get out with it's cover and all. Anybody else feel the same way?
2006 Granite LE 4x4 Crew Cab As the miles go by, so do the best days of our lives.
On any car the only oil that will come out is that is in the filter. The only way for all the oil to drain out throw the oil filter mount the engine must be turning.
Ic ic, thanks for all your guys inputs ![]() helping me decide.... btw, you say 7500 per manual? cause i swear i saw 3750 on mine.... o_O anyone else using synth oils?
06 Frontier NISMO Black 4x4 OP: Sunroof, Rocksford, Bed Extender Performance: AirAid CAI |
