Crankshaft Position Sensor Replacement Walkthrough. - Nissan Frontier Forum
post #1 of 16 (permalink) Old 02-10-2012, 06:33 PM Thread Starter
explorerman's Avatar
Quoted: 23 Post(s)
So I just had to replace my crankshaft position sensor after the truck suddenly stalled and threw a P0335 code at me.
The sensor was pretty cheap at $36 from the local Nissan dealer. Anyway on to the walkthrough......
1. Remove passenger side front wheel.
2. Remove inner wheel well cover. You could probably manage without this step but it does make it much easier.
3. Locate the sensor. It is covered by a rubber boot.
4. Pull the boot back to reveal the sensor. The bolt is a 10mm bolt. TIP!! Remove the connector before undoing the bolt.
5. It's a bit tricky getting the ratchet on because of the trans dipstick tube and a brake line but it's not too bad.
6. Remove sensor.
7. Replace sensor, replace bolt, re-connect wiring, replace inner wheel well cover, put wheel back on. Job Done!!
Old and new sensor side by side.
Hope this helps someone
Explorer
2005 Frontier 4x2 NISMO CC
270,000 miles, original owner. Still going like a champ!
explorerman is online now
The Following 11 Users Say Thank You to explorerman For This Useful Post:
ahinalu (04-26-2015), Clint (02-10-2012), dubie2003 (10-24-2013), FitzIngarage (02-11-2012), jbumx2 (06-24-2016), jlg2002 (11-18-2013), minitruckin (03-24-2015), MOBEEBO (02-10-2012), pianoguy (01-31-2015), Q-Tip (01-25-2015), ToddG (04-05-2014)
post #2 of 16 (permalink) Old 02-10-2012, 07:53 PM
cps
cps's Avatar
Quoted: 29 Post(s)
Great job on your write up! These write ups are what makes this forum great! Nice pictures too...
CPS
cps is offline
post #3 of 16 (permalink) Old 02-10-2012, 09:46 PM
chaz's Avatar
is that blood in pic 5
chaz is offline
post #4 of 16 (permalink) Old 02-10-2012, 10:10 PM
Quoted: 3 Post(s)
Send a message via AIM to Delta
Dang that's good to know! That looks super easy, one of the few things on the truck that actually is
2007 Nismo 4x2, 4.0 Auto - Sold
New ride - 2008 VW Jetta SE - 5 Speed manual
2015 Toyota Camry SE
Delta is offline
post #5 of 16 (permalink) Old 02-10-2012, 11:34 PM
dubie2003's Avatar
Quoted: 10 Post(s)
Besides sudden stall and code, we're there any other precursors in the weeks prior? Did you ru. Thru any trails or water?
07 SE CC Auto
dubie2003 is offline
post #6 of 16 (permalink) Old 02-10-2012, 11:45 PM Thread Starter
Quoted: 23 Post(s)
No it's not blood! lol, not sure what that was.
Truck has been running great but I did have to replace the camshaft position sensor a couple of months ago. When that went, some of the research I did said that when the camshaft sensor goes it is usually followed by the crankshaft sensor and visa versa.
No trail running either but I do work on an island in the Gulf of Mexico, a lot of salt air.
The camshaft sensor was a tough one because of the location and it was about twice the price. I also have 185,000 on the clock.
Hope the info helps!
Explorer
The Following User Says Thank You to explorerman For This Useful Post:
dubie2003 (02-10-2012)
post #7 of 16 (permalink) Old 02-11-2012, 12:11 AM
bonestock's Avatar
get ready to replace your cats....
bonestock is offline
post #8 of 16 (permalink) Old 02-13-2012, 04:37 AM
Great write up! Is this the same for the 2001 4cyl 5spd model?
Frontier7081 is offline
post #9 of 16 (permalink) Old 02-13-2012, 06:33 AM Thread Starter
Quoted: 23 Post(s)
I believe the sensor sits atop the bell housing on the 4 banger. If you google the P0335 code on this site there are a few bits of info on the 4 cyl.
Explorer
post #10 of 16 (permalink) Old 08-12-2013, 02:10 PM
lowEnuff's Avatar
Quoted: 18 Post(s)
quick question on this Explorerman, would your truck be running and all the sudden just shut down? let me know please as I am having a serious with mine and the dealer can not pinpoint it as the (check Engine) light is not on. this sounds like what is happening with mine. let me know
lowEnuff is offline
