Common problems with Frontiers - Page 17 - Nissan Frontier / Navara Forum
  #161 (permalink)
Old 11-17-2012, 07:39 PM
JB'sFrontier's Avatar
Originally Posted by HeavyDuty View Post
Hello all, I searched this forum but had no hits.
When I'm driving with the drivers window down a couple inches, I notice the glass can easily be moved forward and backward with my hand. I only noticed it because it was making a noise and when I grabbed it, the noise stopped.
It's like it's not fastened to the window regulator, just kind of sitting in it instead of attached like I think it should be.
my driver side window does this too. the dealer hasnt been able to fix it
Chat for ClubFrontier Members HERE!
2012 Nissan Frontier CC SV 4x4 - Purchased 8/18/2012
Volant Intake, 20% Tint, Rhino liner, Ultraguage, Black Stock wheels, Fog Lights, Pioneer AVH-P2400BT, LEDs (Interior, Cargo, Backup)
  #162 (permalink)
Old 11-17-2012, 08:39 PM
x_mods's Avatar
All of the windows on my truck can move when they are down. I think it is the design of the track and the lifting mechanism.
I can't remember, but I am thinking it is attached only in the center...
-Nate
  #163 (permalink)
Old 11-17-2012, 09:26 PM
Nomad 13's Avatar
Originally Posted by Pro4XChris View Post
I only have ~3500 miles on it but I have encountered a noise from the brake pedal when turning right (only right) on slightly slick roads. I believe the noise is the electronic stability program responding, but I am really not going fast enough for it to be going off. Within the first week, about 400 miles, this happened and the ABS light came on and the traction control light came on. It hasn't happened since the two occurances, but drove me nuts. Overall, it's been a great truck so far!
My '11 Pro-4 does the same thing. I have a thread looking for answers but none of them have panned out so far.
Mine only started doing it after i installed the 6" lift kit (or thats the first time i started noticing it)
2011 Pro-4X CC Night Armor
6" Fabtech kit, 33/12.5/17 Pro Comp MTs on 17x9 Level 8 Strike 6 wheels, Shrock sliders, BTF diff cover, BDGT, Nismo CAI, Magnaflow cat-back, Custom Deaver spring packs, PRG Adj shackles (ordered), Radflo PBs (ordered), CXJ IMS, Titus Hi-lift bed mounts
Coming soon:
2.5 SAW COs, PRG UCAs, Custom bumpers, Thorley shorties, Custom burgers, HIDs, LED lighting and the list goes on.....
  #164 (permalink)
Old 11-19-2012, 04:18 PM
Originally Posted by Grendel View Post
05 Nismo CC 4wd here with 55k miles.
3) Whenver I change my HVAC to or from the defroster, the little flappers inside the dash shutter and vibrate making a noise.
I know this was a long time ago, but was a cause and/or fix ever found? Mine does the same thing.
  #165 (permalink)
Old 11-19-2012, 05:25 PM
HeavyDuty's Avatar
Thanks for the replies. I didn't want to lift up too much in case it would dislodge it altogether. I guess if you're right, x_mods, then it can kinda pivot and would self align in the window run when it's pushed up.
My truck was already tinted when I bought it, I was thinking the tint guys may have done something, but if it's normal I'll just deal with it.
2012 Frontier CC SV 4x2
02 I35
01 Maxima
95 Nissan
  #166 (permalink)
Old 11-19-2012, 07:27 PM
Send a message via AIM to ZacUSNYR
Not a Frontier issue. It's a Nissan thing. The windows in my Murano did that. Half down they'd vibrate, go up just a small amount and it'd stop. But you could wiggle the window back/forth and up/down.
  #167 (permalink)
Old 11-19-2012, 08:42 PM
x_mods's Avatar
Yea, I think it is pivoting and rocking. Next time I'm in my doors I'll put the camscope in there and check..
-Nate
  #168 (permalink)
Old 11-20-2012, 11:01 AM
I put WeatherGard window vents on my 2012 because it was uncomfortable driving with the window down a little. Now when I put the window up it creaks against the plastic vent and if the window is down a litte it rattles. Move it up or down a little and the noise goes away. Very minor issue.
Thanks for letting us know that the windows are only attached in the middle of the track.
  #169 (permalink)
Old 11-25-2012, 03:08 PM
I have a 12 Pro4X with about 3000 miles on it. I have been noticing a knock or thunk coming from the wheel well or front tire area when making left turns. It happens only when going over a modest crack, hole, or ridge at slower speeds. (20mph). These are not large road hazards, just typical road imperfections anyone encounters, such as a slightly recessed manhole cover. (The manhole cover is not making the clunk There are several of these during my short commute of 2 miles to work. I thought the brake calipers might be causing the clunk but they seem to be solid. It is almost showroom clean underneath and I have never been off road nor have I hit anything. Everything looks OK upon inspection. Has anyone else had this? A forum search has turned up nothing yet.
  #170 (permalink)
Old 11-25-2012, 05:13 PM
RE window creaking i used to have this until dealer added a lubricant to the glass edge seals
RE turning thunk, FWIW get this on front right occasionally, have attributed it to washer fluid slapping the side of the reservoir
2010 Frontier CC LE 4x4
