This thread is for listing common problems Frontiers experience and their solutions. I will try to update this post to list the problems and link to the solution post or thread. This thread is not for chit-chat or rare problems. This is for common problems and their solutions. Thanks.
Is your Tire Pressure Monitoring System light on and you don't know why? Check out our TPMS Problem thread. TPMS problems
Is your 05 Frontier or Xterra's brakes squeeking? Check out the Technical Service Bulletin to see if your truck is covered. Brake TSB NTB06-037c
07 CrewCab:
Wiggley front passenger seat
Rod clatter when first started, cold or hot, untill the oil pressure comes up
Steering wheel Airbag Clock Spring creaks
Rear brake moan when backing up
ASE Master Tech
Toyota Master Tech
The Following User Says Thank You to OldMechanik For This Useful Post:
Have you been able to fix the "wiggley seat" issue you have? Your description is the closest to what I'm experiencing with my '09 CC. Whenever I come to a stop it seems like the car (maybe the seat) has to kinda shift a little forward creating a harder, shifting feeling backwards whenever I accelerate from a dead stop. The best way to describe it is that its like feeling you have something failry heavy in the bed that rolls to the front and to the back with every slightly hard to hard stop. I'm not a car expert by any means but I typically have some general idea what's going on, but not on this one. Can you OR ANYONE help clue me in to what the problem is and how to fix it? I've only had the car for 700 miles and its already driving me crazy. I'd like to have an idea before taking it into the dealership (if they'd even fix it). Thanks!
While the TSB doesn't address the 09's, take a look at it and see what Nissan is doing to fix the issue. Then see if you can either convince your dealership to do something similar or do it yourself.
__________________ 2006 SE KC 4x4 auto -- Shrock BFG AT OEM fogs
2008 Nissan Pathfinder SE -- Traded in July 2012 2012 Nissan Titan PRO4-X -- Nordic White, Leather, Sunroof
The Following User Says Thank You to Phil'sFrontier For This Useful Post:
