All modern vehicles have a compressor cut out under WOT.
OK first of all lets have a short lesson on how this system works for those of us who are squabbling over system operation and whether to call it fast cycling or short cycling. The ECM uses a combination of readings from the a/c pressure sensor, in cabin sensor, and thermal control amplifier. All these sensors (like most items on cars) have 5 different names, so shut up and play nice, you know what i am talking about. The ECM uses these readings and controls compressor clutch engagement accordingly. Therefore, an ecm re-flash would remedy this situation. Also, normal cycling is used for a variety of reasons. Fuel economy yes, but when fast cycling this will be compromised as loading and unloading the engine uses more fuel. Mostly it is used to control cabin temperature and prevent evaporator freeze up, as well as prevent wear etc. finally, this doesnt seem to be a problem off idle, and yes it should happen more often with the fan on 1 setting as the lower the fan speed, the cooler the evaportor will be.
hi maineruner im new to this forum as I live in the uk but I can not stop myself from commenting This guy is trying to help he has a problem like alot of you dont be negative and dont be picky about his discription/title of the problem. This is a forum where we all pull together and unite to sort problems and fight in numbers dont want to get heavy but as I said the guys put himself forward to help. Hope he gets it sorted if you want to log on to the uk sites may give you more ammo to fight nissan with good luck |
Anyway, I'm sending you a PM for someone who might be able to help you and if not he's still a great friend to have and he's an awesome guy.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18 _____________ ![]() . Check out my Gallery! . Last edited by Pops : 05-13-2008 at 05:01 PM. |
Ok cool. I am all for helping in any way that I can. Not to be negative, but I really don't think that anything will come of this since Nissan doesn't even seem to be interested in helping to fix some of the here-and-now problems that people are having. But, it never hurts to try!
Also, thanks to "nissanmastatek" for bringing this to our attention. In the mean time, I think I will keep my fan on at least the "2" setting unless I am on the highway. |
thanks for your help guys. Like I said before, it takes an act of congress to get nissan to lift a finger. And, as you said pops, i am no longer an employee, but like all of us i paid 20k for this thing and a simple engineering issue should be taken care of. Oh and dont get me started on the Armada/Titan vehicles, that list is a mile long. I will contact Nissan shortly and let you all know what happens. I expect the usual phone tag but we will hope for better. thanks again
