Changed belt tensioner...started making noise again?!?! - Nissan Frontier Forum
post #1 of 22 (permalink) Old 12-09-2010, 01:48 PM Thread Starter
Quoted: 5 Post(s)
I changed the belt tensioner on my 4.0L about 1600 miles ago and all was quiet...until I washed it the other day and sprayed off the engine (with low pressure). Now there's a new "chirping" noise, not as bad as it was, but still there. I didn't know what the part number of the redesigned tensioner was but I contacted a friend who is a tech at a local Nissan dealer. He said that the part number I had was the latest part number they had. The tensioner did look a little different as far as the casting of it but other than that, it looked the same just a different number.
My question is what the hell happened? Could it be that the new tensioner could have caused a bearing on another pulley to start chirping? Could my spraying off the engine have caused something to start chirping? I haven't had a chance to investigate yet but I plan to do that tomorrow during the spark plug change.
Thanks for any input!
2005 Frontier NISMO CC Electric Blue (Entire front cap has been repainted.)(Ex-wife's problem now)
2009 G8 GT Stryker Blue Met SOLD
1998 Camaro SS Silver/Black 6spd
1997 S-10 w/ lots done
2007 Trailblazer SS
Nismo_Noob is offline
post #2 of 22 (permalink) Old 12-09-2010, 01:54 PM
dubie2003's Avatar
Quoted: 10 Post(s)
More then likely it is slipping of the belt on a pulley. Give it a few days to completely dry off and see if it keeps squeeking. When was the belt last replaced? May be worth doing that too. Over time they tend to wear down and get glazed and they slip so it may just be time to replace.
P.S. I vote gatorback belts since they have a great design and last forever.
07 SE CC Auto
dubie2003 is offline
post #3 of 22 (permalink) Old 12-09-2010, 01:58 PM
some one said with engine off take abar of soap try to wipe it on the contact area of the fan belt all the way around it see if that does any thing
frontier bob1 is offline
post #4 of 22 (permalink) Old 12-10-2010, 12:19 PM Thread Starter
Quoted: 5 Post(s)
I changed the belt (Gates) when I changed the pulley. Not sure about the soap thing? The wife drives it everyday so I don't get to listen for it but I'm gonna check it out this afternoon when I'm changing the plugs. I'm hoping it's not doing it any more because I don't want to have to take it back to the dealer and argue my point.
*UPDATE*
The noise is a almost constant chirping and it doesn't get faster with higher RPMs like a belt squeal would. It's definitely coming from around the tensioner and will be 1 of 3 things down there: tensioner, alternator or power steering pump. I looked at the new tensioner and the belt is riding on the very edge of the pulley, I mean almost hanging off the front, with maybe 1mm of the pulley showing. Is that normal?
Now here's the kicker, when removing the upper intake to change the PS plugs, I got some antifreeze on the belt down there. When I started it up afterward, there was no noise for about 20-30 seconds then it started again. That makes it sound like the belt unless that antifreeze some how lubricated whatever bearing might be going out. Thoughts?
2007 Trailblazer SS
post #5 of 22 (permalink) Old 12-10-2010, 07:39 PM
Send a message via AIM to xshellshock
spray the belt with a little pb, if the noise goes away, its the belt. Otherwise take a long screwdriver and put it on the bolts that hold the pullies, and put the handle end to your ear. you'll be able to hear what pulley is making noise that way.
2007 Frontier SE Crew Cab 4x4 6 speed 6ft bed
xshellshock is offline
post #6 of 22 (permalink) Old 12-11-2010, 05:16 AM
FitzIngarage's Avatar
Quoted: 86 Post(s)
[ I'm still within my powertrain warranty, so am hoping that it's the tensioner. ]
I never replaced my tensioner and the high-pitched squeal noise is back. I called the Dealer this morning and the tensioner is NOT covered by the powertrain warranty. I confirmed their statement reading my warranty book.
I think I'll try the repair myself when the squeal finally drives me nuts.. Lots of info in this thread:
Belt tensioner replacement
Getting the 14mm tensioner mounting bolt out seems like the toughest part of the job, as it's in tight. I'm still a bit confused as to exactly what sort of wrench people used.
FitzIngarage is offline
post #7 of 22 (permalink) Old 12-11-2010, 06:26 AM
Aussie Frontier's Avatar
I just had exactly the sqame thing.Did the soap trick and it went away for a while.New belt and 20 mins work and all good again.
Black Ice
Custom Paint
Glasurit Pure Black with 5% Blue Pearl
Wheels by Speedy Australia
"The only true Wilderness is the space between a Tree Huggers ears "
Aussie Frontier is offline
post #8 of 22 (permalink) Old 12-11-2010, 07:44 AM
mrbill65's Avatar
When I replaced my belt on an 07 4X4 Nismo this week there was two belts one with an enhancement kit, not sure what the enhancement kit is, and one with out I could not find a belt for one with the enhancement kit except at the dealer. I am wondering if by chance you need the belt for the enhancement kit? The oem belt was thinner and the ribs were slightly different.
mrbill65 is offline
post #9 of 22 (permalink) Old 12-11-2010, 08:04 AM
I'm on my third belt tensioner on my'06. I thought mine would have been covered under power train warranty but it wasn't. Explanation was "It's not actually part of the drive train." The last two tensioners were the updated ones and the last time it was changed they warranted the part as a "courtesy". Big whoop! It's starting to chirp again. This is getting old.
Bones750 is offline
post #10 of 22 (permalink) Old 12-11-2010, 09:00 AM
mrbill65's Avatar
Is this belt tensioner only an 05/06 year problem, I have 92K miles and have never had this problem. when I changed my belt the idler pulley spun smooth and have never heard any kind of chirping.
Thanks
Bill
mrbill65 is offline
