Old 07-02-2008, 01:56 PM
Can someone confirm this OEM oil filter is ok?
Picked up an OEM oil filter today and noticed it is part number 65F ... not 9E.
I called three dealers and they said it's ok, but I want to check here before I change the oil. I change every 4K.
thanks.
2007 SE V6 4x4 Crew Cab Long Bed, Radiant Silver: SE Value Package, Tow Package, OEM Hood Protector, OEM Fog Lights, Headlight Adjust (1.5 turns), 4 Bed Rope Hooks, 8 Utili-track Cleats & 2 RockyMount Clutch SD, Pathfinder Switch Covers, OEM Rubber Floor Mats, G2 Bakflip, 2" Blind Spot Mirrors, OEM Chrome Handles, EZDown, Street Scene Speed Grill (brushed) ...
Old 07-02-2008, 02:00 PM
WestCo Justin's Avatar
Shift_Site_Sponsor
D40 V6 uses 15208-9E000
15208-65F0C(0) is for 2.5, both will work but 9E has a slight bit more capacity.
Essentially they both are the same diameter and thread pitch is the same, just one is longer.
West Covina Nissan
205 N. Citrus St. West Covina CA
www.thenismoshop.com
626-732-1000 x6375
Old 07-02-2008, 02:11 PM
Thanks, Justin.
I did notice the 65F is shorter ... and a few dollars less expensive than the 9E.
Thanks for letting me know it will be ok. Any reason NOT to use it in the future if it's less expensive?
Old 07-02-2008, 02:21 PM
I'd pass...
Personally I only use the 15208-9E000 filter. They are cheap anyway.
What you save today could come back to visit tomorrow.
2008 Nissan Frontier LE Crew Cab Long Bed 4X4 in Radiant Silver
2007 Nissan Pathfinder SE 4X4 in Desert Stone
Old 07-09-2008, 09:45 PM
Does anyone on the board use NAPA Gold, PN1356? These are made by Wix I believe and usually are highly rated.
I have a few left over from my '00 Maxima SE and NAPA says both motors use the same filter.
Mike
2005 Frontier KC NISMO, 4x2 auto, Super Black/Charcoal
2004 Volkswagen R32, Deep Blue Pearl & Leather
Old 07-10-2008, 05:58 AM
I have used these and they run just fine. I have always been a fan of NAPA Gold filters as they are made by Wix. many NAPA stores have one cut open at the counter to allow comparison to a Fram filter. Internally, the NAPA is outstanding with a good anti-drainback valve (where required), metal endcaps and excellent overall construction. I ran a Chevy truck for ten years using these and never had an engine issue. When my supply of Nissan filters runs out, I am switching over to these for my Frontier.
Old 07-10-2008, 01:37 PM
MarkG's Avatar
I use the Napa 1356, great quality at a decent price. Since my Maxima also uses this filter, I buy them by the case at fleetfilter.com They also have cabin filters.
2008 CC SE 4X2 6MT AZTEC RED ALERT
Hellwig, Prothane, aFe ProDryS, Redline Tuning, Unistrut, Xport, Nokya HyperYellow H9, Philips Xtreme...
Old 07-10-2008, 08:50 PM
Upgraded's Avatar
Since we're on the subject, what filter does the Titan use? is it bigger? same threadpitch? Might try opne next change. We used the run the filters from from the automatics when I had my Eclipse. The turbo ones were very tiny to clear the downpie and heatshields. with the aftermarket stuff you didn't have this issue so you could get the much larger one from the auto on it. curious, thanks.
2007 SE CrewCab LongBed
PRG mini lift, Undercover tonnaue
Old 07-10-2008, 09:31 PM
Shift_Site_Sponsor
The Titan uses the 9E000 which is the longer of the two, so yes its the same thread pitch.
West Covina Nissan
626-732-1000 x6375
Old 07-10-2008, 10:10 PM
x2 Reading my mind. Fleetfilter.com is the best! I usually place one huge order a year for all my vehicles. I love Napa gold filters! The Titan filter sounds interesting though.
Thanks for the replies guys.
Mike
