Caliper Bracket Removal
What is the best way to get the nuts off the caliper bracket. I think they are 7/8 inch, but they won't budge and it's hard to put any weight on the ratchet when it's deep in the wheel well. I gotta replace my rotors and I gotta get the caliper bracket off. Should I buy a rubber mallet and take it to the wrench, or just get a hernia getting it the old fashioned way?
![]() ___________________________________________ '04 Super Black CC K&N intake, Nismo exhaust, Painted Calipers, NGK Iridium IX sparkplugs w/ wires, Nismo Floormats, Street Scene Grill, Sirius, Club Frontier Sticker, PowerSlot Slotted Rotors |
I believe they are 19mm, and you can use a 1/2" breaker bar, 1/2" air gun or a little heat from a torch
![]() 2007 Crew Cab NISMO Ventvisors, Extang Tonneau Cover, Steelcraft Step Bars |
i'm actually using a breaker bar, but I don't have a 19mm socket, but the 7/8 goes on snug. It's on there tight, hasn't been removed for 50,000 miles. I was thinking about using liquid wrench deep penetration.
I got it, just had to position myself better and have my g/f help!
![]() ___________________________________________ '04 Super Black CC K&N intake, Nismo exhaust, Painted Calipers, NGK Iridium IX sparkplugs w/ wires, Nismo Floormats, Street Scene Grill, Sirius, Club Frontier Sticker, PowerSlot Slotted Rotors Last edited by Mountaineer : 08-09-2008 at 09:13 PM. Reason: Automerged Doublepost |
Every fastener on our vehicles (a virtually every vehicle made these days) is metric. If you are going to be doing work on your vehicles, do yourself a favor and go to Sears and pickup a set of Metric 6pt sockets - and ratchets if you do not have good ones. This time, your standard socket may have been close enough, but next time you may round off a bolt and then you will have created a major headache for yourself. You'll be able to buy a basic set for less than you saved by doing the brakes yourself - and they will last you a lifetime. Also, for rusty bolts nothing is better than PB Blaster. You can buy it anywhere. |
Good job breaking it loose. Nothing will pee on your parade worse then when you go to do a normal/simple job and run into a snag like that. When ever I know how much time it should take me to do a job I always double it in my mind just for such things. Never know what you'll run into. Then when I get a job done in half the time I initially predicted, I'm like "dang I'm gooooood!" ![]()
2006 4x4 SE Crew Cab, 6 speed, Sunroof - Red Alert/ 2006 Altima SE-R Loaded - Super Black Click here for modifications and pics. My write ups/modifications threads: Alternate tweeter location / stereo install synopsis (PICS!) Custom fiberglass enclosure is finally FINISHED !! ToddG's upgrades/mods (with pics!) |
