Old 05-10-2008, 05:22 PM
In cab filter?
I have a 2001 frontier, does it have an in cab filter? Thanks. Also, what does advancing the timing 2 degrees do?
Old 05-10-2008, 07:23 PM
steve0616's Avatar
If you have the in cab filter there should be a sticker in the glove box about it.
2004 Electric Blue CC SB LE:
Old 05-10-2008, 07:54 PM
jerryp58's Avatar
My '04 XE had the slot for the filters, but from the factory, it just had a plate covering that slot. I put some filters in around 15k miles when I went to "replace" the factory ones. The glove box can be removed pretty easily i think it was 4 or 6 screws. I'm going to be replacing mine again any day now.
Jerry
My Frontier Page
Old 05-11-2008, 10:57 PM
Frontier2's Avatar
Some of the older ones may have to have the slot cut out for the filters to slide in,no big deal.
06 MAJESTIC BLUE 4X2 LE KC
Old 05-12-2008, 09:51 AM
slow95tsi's Avatar
My 01 has a cabin filter. Take the 6 screws out of the dash the go around the glove box and remove it. You will see the filter in the middle of the heater / ac box. There will be a clip at the bottom that pops off and then you slide the filter out. The filter in mine was a 2 piece filter. It was never serviced since the truck was new, soooo it was pretty gross. I blew it out with the air hose then took a shop vac to it.
