Old 05-14-2008, 09:08 PM
NCFronty's Avatar
Anyone have transmission problems?
I am just trying gauge whether anyone has experienced any kind of problems with their automatic transmissions in a Gen II Frontier 05+? Today on my way home my truck started acting really strange. It seemed as if it were going to die if I took my foot off the gas. Also it seemed to lag between shifts making them king drawn out. Kinda freaked me out. I drive the truck every day and can tell when something doesn't seem right. I do have low gas, but the light just came on. I did just do the TB screen removal, and I do still have an IMS with bad gaskets still installed. Anyone have a transmission or engine problem with their Gen II's? Just trying to figure it out because I can't be without a vehicle.
2006 Frontier CC 4x4 LE NISMO SPORT Stormgray - Performance: Airaid Quickfit intake w/AEM dry filter,WRP I.M.S.,2* Advance,TB Screen removalExterior:Nissan running boards,Nissan hood guard,PIAA Xtreme White Plus bulbs in headlights & Fogs,Black Bullet BullBar,PIAA 520 Ion Crystal fogs, Hidden Hitch,OEM Nismo skidplates,Truck-Tec tonneau,Thule roof rack w/wind deflector,Billet Grill 4 piece set Interior:Kenwood CD player & in-dash 4 Disc Minidisc changer,Panasonic S2 GPS Suspension:PRG 2.5" lift w/Radflo 2.0 Coilovers and 2" Deavers,Rear Bilsteins,SuspensionConnection Titan Sway bar bushings Wheels/Tires:Nissan LE 17" 4 spoke wheels, 265/70/17 Bridgestone Dueler REVOs Other:McMaster-Carr Hood lift mod, Painted windshield wiper cowling
Old 05-14-2008, 09:09 PM
Inyourface1650's Avatar
what was it doing at idle? If it revs, drops, revs, drops, revs drops, or kinda sounds like it has a mean cam at idle, its going to be an air leak, which would be the IMS. Other then that though......
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
Old 05-14-2008, 09:27 PM
NCFronty's Avatar
I did take the back cover off the engine(the one that says 4.0) and listened to the engine. It sort of sounding like a light knocking sound, sort of diesel sounding. It didn't seem to fluctuate in the rpms at idle.
Old 05-14-2008, 09:45 PM
trainwreck's Avatar
Mine kinda slips a lil, only when im giving it gas and it trys to change gears and it slips hard. I just asume its the way the tranny is programed to act with the throtle responce. It needs some work!
2007 Frontier w/ 2in. lift with 285/75/16 Mickey Tompson MTZ. Skids and sliders to come.
Old 05-14-2008, 09:56 PM
shift_this's Avatar
no check engine light???
Old 05-15-2008, 12:12 PM
Send a message via AIM to Rick F
Hope you find out what is wrong. No problems here. The only thing I don't like is while on cruise control and coming down hill, the tranny feels like it is searching for a higher gear once in a while. No slippage yet and still going strong.
Old 05-15-2008, 12:32 PM
I always thought my transmission was a little too jerky at certain points. I.E. cruising in town between 40-45 mph let off the gas and rolling, get back on the gas and it's like theres jerk or rough feel as the engine and torque converter try to match speed again. I bought this truck becasue I need an automatic becasue I drive so much and also because I need that trans to be bullet proof. I'm debating on changing the trans fluid out with something else any recommendations?
-Ryan
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body,
but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming
"Wow! What a Ride!"
'08 Nissan Frontier SE Crew Cab Long Box 4x4 Avalanche, Steel ,tow pkg, moonroof etc..
Old 05-15-2008, 01:15 PM
-Ryan
That's probably slack in the rear differential. Different problem
ONAZ
Old 05-15-2008, 01:37 PM
NCFronty's Avatar
No check engine light, but there definitly seems like something wrong. The dealer said that often the ECU will show codes when plugged into it but there will be no engine light on. I am thinking vaccuum leak from the stupid IMS. I will take it off friday evening and see what I find out.
Old 05-16-2008, 04:11 PM
-Ryan
Royal Purple Max ATF should set your tranny straight.
2005 Electric Blue LE CC 2WD
Clarion DXZ765MP Head Unit
Planet Audio 6.5" Components
Power Acoustik LT480/2 Amp (Works better than I thought it would!!)
1996 Lanzar DC-10 SVC 4 Ohm Sub
Mid 90's Orion Cobalt 702 Amp (I like the old school!)
Xact Visor Sirius Tuner
Harmon Kardon Drive+Play iPod module
