Old 06-26-2008, 12:53 AM
elementalJ's Avatar
Anyone had engine work done to their 05-08 fronty?
Im about to take her in to the stealership, to discuss the morning piston rattle, that evidently no one else has. Along with that D&*M crooked front bumper. Was wondering if anyone else had this issue, and had it fixed.
I have the TSB for the "Camshaft Sprocket Rattle" to take with me.
Has anyone else had this issue, and if so, what was the solution?
I would like to have all my bases covered before I get there. Its hard to deal with dealers these days to get things done. They all want to say that they dont know what youre talking about....
And I dont feel like trying to get rid of her. Just want the issues resolved before I park it in the showroom windows......
Any help would be greatly appreciated.....j
I was pulled, kicking and screaming from a Ridgeline...
And now, after the intervention, I feel much better!
Old 06-26-2008, 10:57 AM
RedAlert's Avatar
I dont have the engine rattle, but after a minor fender bender(hitand run, f'n ahole), my bumper was slightly off. I drove me nuts, and I wanted it perfect. Not hard, but time consuming. Take the grill off. Look from the top down next to the headlights, you will see two bolt heads that go through the mounting tabs for the bumper. Loosen the bolts a few turns and insert some body adjument washers(they look like small horseshoes with a tab) under the bumper mount. 2- 1/8" made the muper come up just shy of 1/4" which is all I needed.
Old 06-26-2008, 02:16 PM
Jeff024's Avatar
Send a message via AIM to Jeff024 Send a message via Yahoo to Jeff024
I had an engine whine around 40k they tried 3 time to fix it and didnt so at around 47k nissan put a new motor in my truck
PICS OF MY TRUCKS
Old 06-27-2008, 03:36 PM
Was this whine all the time or at certain speeds? I have some noise at highway speeds whenever my foot is on the gas at constant or increasing speeds. If I let off it stops.
Old 06-27-2008, 06:00 PM
MrEd's Avatar
I've got the rattle also, 19K miles so far. it is very brief at start up. does definately sound like a piston on the drivers side rattleing at start up.
07 SE CC LB 4X4 STORM GRAY
2"LIFT, HELLWIG REAR SWAY BAR, 265/70/18 SHOES
Old 06-27-2008, 06:58 PM
Jeff024's Avatar
it was all the time at the end but when it started it was just in the morning until it got warm but got worse over time
PICS OF MY TRUCKS
Old 06-27-2008, 07:40 PM
MrEd's Avatar
yeh, mine seems to be getting worse to, it does it now after sitting for 4 or more hours.
i guess i need to take it to the dealer for them to listen to and document huh.
Old 06-30-2008, 02:48 PM
Guys,
Bought an 08 CC SE V6 6ft bed with Manual transmission (3 months old 560 miles). I've been having a knock/ticking noise after the engine is warmed up and the noise gets louder as RPM's increase. Today I took it to the dealership and their head mechanic said it was a normal noise from the engine and could even be the flywheel, but it was a normal noise.
Anyone else have this noise coming from the drivers side lower portion of the engine? I think something is loose internally personally, and I will give it time to see if it gets worse. I did get it documented that it started at 500 miles though, so that will help in the fight with Nissan North America.
Old 06-30-2008, 03:17 PM
StormFrontier's Avatar
are you sure you aren't hearing the hydraulic timing chain tensioner?
Jordan, ME (EIT)
2008 Storm Gray SE CC 4x4 MT: Custom made LED tails, debadged rearend, line-of-fire tailgate LED strip, Pioneer FH-P8000BT, 760W Pioneer amp/1100W Xplod 10", Nismo CAI, custom Magnaflow dual in/dual out
1993 Hardbody (RIP)
1996 Maxima (gave it to my bro)
Old 06-30-2008, 04:15 PM
MrEd's Avatar
no i'm not sure, i have exactly the same noises from the drivers side as buddro. along with my piston rattle at start up.
