abs/slip light on...no 4wd - Nissan Frontier / Navara Forum
Old 01-23-2013, 05:54 AM
nitricacid's Avatar
First real problem with truck at 140k miles. Baby has been drinkin gas and running strong.
So one day abs decides to activate on dry pavement while braking. Did this a couple times while braking..and than both abs&slip light up on the dash. So i have no abs(no big deal) but can't get it into 4wd(big deal)
Off to the stealership we go...
maybe wheel sensor? or bad wiring? or bad abs actuator?
KEEP RIGHT PASS LEFT. What could that mean? Why are you blocking traffic by driving so slow in the left lane? Now get the HELL outta the way!!! Keep traffic flowing...Obey the rules of the road
Old 01-23-2013, 10:39 AM
How old is the brake fluid? Any mud packed into the ABS sensor teeth?
2012 Frontier PRO-4X Crew Cab 6-speed manual
Old 01-23-2013, 01:24 PM
haveacigar's Avatar
Probably snapped/ stretched ABS wire to one of the wheels. The stealer is gonna put a big rake up your bum for this. This is one of their favorite cash grabs
I'd at least check the wires around your front upper control arm (these usually go first) And the plastic connectors for the rear lines (beside the evap canister). The stealer will replace the whole sensor instead of repairing the wire.
05' nismo 6speed 4x4, T-Swapped, M205, 4.56 gears, 315/70/17, shrocked, K&N CAI, IMS, TBS, uprev, under armor, 2" BL, Heim outer tie rods, dual batteries, Borla Dual Exhaust Build, Rear Bumper Build
The Following 2 Users Say Thank You to haveacigar For This Useful Post:
nitricacid (01-23-2013), the007forum (01-23-2013)
Old 01-23-2013, 01:39 PM
the007forum's Avatar
Correct Haveacigar, your gonna go far. You can repair that line yourself or get a junkyard replacement to save on cost.
Old 01-23-2013, 04:23 PM
nitricacid's Avatar
Front right abs sensor is pulling up on the consult at the dealer...
So for only $550 they will take care of this.
Wish is wasn't sooooo damn cold out...or had a heated garage.
Old 01-23-2013, 05:34 PM
Clint's Avatar
Where in New Jersey are you from?
2012 Dodge Challenger SRT8 Yellow Jacket Edition 6-Speed in Stinger Yellow
