4wd Light dimly lit when in 2wd
'04 XE Automatic
I just noticed last night the 4wd light on my dash cluster is VERY dimly lit when I am in 2wd. So dim that you can't see it during the day. -When I shift into 4wd the light fully lights up, and goes back to dim when shifted back to 2wd. -4wd is engaging and disengaging properly. -The light is dim whether the parking lights are on or off. -I haven't used 4wd in a few months. The only cause that comes to mind is that my battery died a week or so ago, it may have been doing this since then. (now that I write this I might try disconnecting the battery to see what that does) I searched around on this site and couldn't find any other posts with the same problem. Any ideas are appreciated, thanks. |
i dont think its nothing to worry about since when you put it in 4wd it lights up bright and then gets dim again when you shut it off. ill double check mine tonight and let you know if mine is like that... ive never noticed it.
2006 SE kc. 4x4 6spd. Storm gray. calmini 2.5'' lift. 255/85 Maxxis Bighorn(ey)s. De-badged. No person was ever honored for what he received. Honor has been awarded for what he gave. - Calvin Coolidge |
its probably light being cought from something else. if it works, its fine
It was the same in my 03 Frontier. Nothing to worry about...
2007 Nissan Frontier Nismo CC 4x4: 33 in. BFG MT KM2s, 3 in. Calmini Spacers, 3 in. Deaver AALs, Bilstein 5125s, Shrockworks Skids, Cobra 75 WXST CB, Wilson CB Antenna, Penski Custom Sliders, Penski Hi-Lift Jack Mount, 2° Timing Advance, K&N, Air Box Modification, Custom Arizona Pin Striping ![]() Offroad Nissans of Arizona |
Sound like a short to ground.
I have heard of this before, and no problems came of it.
![]() 1994 Pathfinder SE 4A 4x4. Mall Crawler. 2007 NISMO KC 6M 4x4 - Gone 2005 SE KC 6M 2x4 - Gone 2002 SE CC 4A 2x4 - Gone ONAZ Last edited by Inyourface1650 : 11-26-2007 at 02:22 AM. Reason: Automerged Doublepost |
Thanks for all the replies.
I pulled the terminal off the battery and double checked all the fuses and the light is still there. I'll leave it for now, but it will probably bug me after a while and I'll end up pulling apart the whole dash cluster. I'll post back here if anything comes of it. |
Don't pull the dash. Check for water in the connector to the t-case.
