2008 Frontier Driveshaft - Nissan Frontier Forum
post #1 of 11 (permalink) Old 07-25-2010, 06:48 PM Thread Starter
I own a 2008 Frontier 4x4 with a six inch lift kit. I was driving last night from Ga to Fl and my drive shaft snapped. What could have cause this?
Pilot028 is offline
post #2 of 11 (permalink) Old 07-25-2010, 07:00 PM
penski61's Avatar
im guessing you busted a u-joint because of your lift , you need to correct the driveline angle so you dont keep blowing out u-joints
02 sas'd 1st gen
07 sas'd 2nd gen
02 chevy reg cab with 8.1
penski61 is offline
post #3 of 11 (permalink) Old 07-25-2010, 07:10 PM Thread Starter
The lift kit was installed by the local Nissan dealer before I bought it. The truck is still under factory warranty. What should I tell Nissan to avoid this in the future.
Pilot028 is offline
post #4 of 11 (permalink) Old 07-25-2010, 07:17 PM
Clint's Avatar
Quoted: 362 Post(s)
How do you do that?
Clint is offline
post #5 of 11 (permalink) Old 07-25-2010, 07:21 PM
penski61's Avatar
you can either buy wedge shims to put in between the leaf springs and spring perch to rotate the front of the axle up , or cut all the brackets off the axle rotate the axle so the pinion is in line with the output on either the t-case or transmission then weld new brackets back on
shims obviously will be the easiest way
02 sas'd 1st gen
07 sas'd 2nd gen
penski61 is offline
The Following User Says Thank You to penski61 For This Useful Post:
NovaBeJota (07-12-2016)
post #6 of 11 (permalink) Old 07-25-2010, 07:26 PM
Clint's Avatar
Quoted: 362 Post(s)
does changing the angle have any affect on the oil level and lubrication?
Clint is offline
post #7 of 11 (permalink) Old 07-25-2010, 07:31 PM
penski61's Avatar
its only a minimum angle change , maybe 3-4* so it really wont have an affect on the lubrication
02 sas'd 1st gen
07 sas'd 2nd gen
penski61 is offline
post #8 of 11 (permalink) Old 07-25-2010, 07:40 PM Thread Starter
Thanks for the advise. I wonder what Nissan will do to it.
Pilot028 is offline
post #9 of 11 (permalink) Old 07-25-2010, 10:11 PM
Clint's Avatar
Quoted: 362 Post(s)
I imagine moving the brackets would be the better of the two methods.
Clint is offline
post #10 of 11 (permalink) Old 07-25-2010, 10:18 PM
dubie2003's Avatar
Quoted: 11 Post(s)
What 6" lift kit did they use? I am not sure they are going to warranty the work at all. They may play the "warranty void" card and play dumb.
If they do anything, I would imagine they are going to just replace the Dshaft and call it a day. They will hope that you are out of warranty the next time it happens and then want to charge you.
Thinking about it, I am going to laugh a bit if they used a simple block lift. This will cause extreme axle wrap on our Frontier's.
Moving the brackets will work but if you change out the lift in the future or do anything, it will have to be changed again. I would stick with the shim or tappered lift blocks if you have to use blocks and leave it like that for a bit.
07 SE CC Auto
dubie2003 is offline
