» Sponsors
» Sponsors
Old 03-19-2010, 09:12 PM
06 A/T does NOT like shifting out of OD!
I'm hoping someone can tell me if this is 'normal'. There are one or two mountain passes on my daily commute home on the interstate (65MPH speed limit). Unless I hit them going 70-75, the engine bogs too much for my liking (and I don't usually drive that fast anyway). SO, I like to turn off OD before I hit these sections.
In one particular section, there's a slight downhill prior that I try to coast down to around 60-62MPH and turn off OD. However, more often than not, I get a very loud CLUNK from the transmission when I do so. The only time it *doesn't*, is if I'm 100% coasting, foot off the pedal, doing 55MPH (cars backing up behind me, because most are racing to make the hill).
Today for instance, on a flat section, I was doing 60MPH, ONLY enough pedal to maintain speed, and I still get this clunk. I never get this noise/jolt when turning OD on.
I expect to get a bit of a blip in RPM coming out of OD, but this is more than that. It's not like I'm mashing the pedal/racing when I do this.
So do any of you folks shift in and out of OD on the interstate? What's your experience? Truck has 71,000, A/T has 20,000 (replaced under warranty for prior owner - radiator broke down, destroyed the AT).
Thanks for reading!
Old 03-20-2010, 02:02 AM
KRAKR's Avatar
Send a message via Yahoo to KRAKR
My 05 Nismo A/T is totally silent when shifting in/out of OD. I would take it in, specially if it still has warrenty.
The KRAKR
05 Frontier Nismo
-Stillen Supercharged w/ TB Spacer/ Nismo Cold air intake with open K&N
-3" Suspention/2" body
-285-75-r16 Toyo MT
-Shrock front bumper/9500# Ramsey
Old 03-20-2010, 02:17 AM
krichards's Avatar
Mine at 40mph with low load (flats) with any throttle input or removal clunks pretty embarrassingly. 44,000mi NISMO CC. I mentioned it to the dealer, they didn't seem concerned.
2006 Frontier NISMO 4x4 CC
2-1/2 Lift leveling kit
Leer Canopy
Old 03-20-2010, 03:48 AM
Fixed under warranty forum....
Do you have a clunk and a vibration in the driveshaft when in park and shifting to R?????
Pressure your dealer...had mine replaced
2005 Black CC LE
Old 03-20-2010, 09:39 AM
I have 38K on my '06 and shifting to and from OD is silent.
'06 Red Alert Frontier 4X4
Pro Comp 6089 16X8 with Michelin LTX AT2
UWS Toolbox
Old 03-20-2010, 09:55 AM
Maybe it's just me, it's an AUTO trans. so why do you change any setting especially at speed? I'm not saying your doesn't have an issue. What happenes if you leave it alone?
Old 03-20-2010, 12:52 PM
Doesn't matter if its an auto trans. If everyone else is not having the same issue then something is wrong.
I sometimes click off the OD if I feel like the engine is bogging down. Feels like it keeps the engine from lugging down.
UWS Toolbox
Old 03-20-2010, 02:04 PM
Mine shifts in and out of O/D like crap... 40mph is the death of these trucks (when O/D engages/Disengages) Dealership and other members on here said it is normal... I don't care though, if it breaks, not my problem... warranty to 65K but truck will be gone before that when the lease is up..
'08 Nismo CC 4WD
Old 03-20-2010, 04:36 PM
I understand there actually could be a problem, but at the speeds he's referring to why turn off the O/D button. If it's at a speed it keeps hunting for a gear is a different story.
Our trucks shift down on a hill like an engine brake. Some think thees an issue but it's made to do it. The Nissan 5 speed auto is unlike any other auto most have driven.
powertrain warranty is up to 60K
Old 03-20-2010, 04:52 PM
00 FRONTIER's Avatar
The OD and/or tranny in these trucks is definately lacking in the satisfactory department. Mine has bothered me since day 3 when I figured out what it was doing.
Mine has always had an issue with downshifting when going up hills, it wants to hold the gear its in way too long, until the engine is bogging and pinging and the RPM's are around 1200 which is way too low. Every other vehicle I have had does not do this and it can be very annoying.
With that being said, around town I leave the OD off. When I get on the highway I leave it on. I've switched it on and off a few times on the freeway and while not having any problems, I didnt seem to really like it.
I would just leave it in OD and use the accelerater pedal to kick the tranny down when necessary.
2009 Frontier SE CC 4x4, PRG minilift 2" Fr/ 1" R, 265/75/16 Goodyear Wrangler Duratrac's, pathfinder switch plates and debadged
