06 Fuel sensor - gauge showing NO GAS
Right after my 36K warranty runs out my fuel gauge goes bad, called the Nissan garage and they told me they have replaced several of these sensors and it was inside the tank, total cost would be $350, 150 for the sensor and 200 labor because the tank has to come off, Iam going in tomorrow for a driver side valve cover gasket and let them listen to the throw out bearing again, if they dont hear the grinding throw out bearing Iam taking it elsewhere and having that fixed, that is covered under the 60K powertrain warranty. Thanks guys..
2006 Nissan Frontier KC SE 4x4 - Mods --> AirAid CAI, Nissan (DeeZee) Tube Steps , Factory Fog Kit , Pioneer DEH-P9800BT JBL GTO 6x9 & Polk Audio db650 6.5, MTX 8" Truck Boxs, Whistler PRO58 , Wet Okole SeatCovers, Bilstein Titan Struts, (Front) Bilstein Shocks (Rear) |
Nissan should fix the fuel gauge under a "good will" repair. As far as the throw out bearing goes it is not covered beyond the first 12,000 miles. Good luck.
2008 Nissan Frontier LE Crew Cab Long Bed 4X4 in Radiant Silver 2007 Nissan Pathfinder SE 4X4 in Desert Stone |
Same thing just happend to my 05 Nismo KC at 44K. Took it to a good repair guy that works on my truck. He charged me about $300, so I guess I saved $50 by not going to the Stealership. It's pretty sucky that these are breaking at such low mileage. Smells like a future class action claim to me.
We Must Be Twins
Sounds like you are having the exact same issues I've had with my 06. I purchased it in October 2006 w/ 0 miles. Today I turned 97,000.. yes 97K. The fuel sending unit went out at exactly the same mileage and to top it off my rear diff said bye bye at 62K. "Good Will" I don't think so... have your checkbook ready.
Good luck |
Search tool must be really hard to use, its a pretty common issue.
And the irony of it all is...only the DANA axles fail. Corporate Nissan ones dont. ![]() heres how to replace it How to Replace a Fuel Level Sending Unit D40
![]() 1994 Pathfinder SE 4A 4x4. Mall Crawler. 2007 NISMO KC 6M 4x4 - Gone 2005 SE KC 6M 2x4 - Gone 2002 SE CC 4A 2x4 - Gone ONAZ Last edited by Inyourface1650 : 08-27-2008 at 11:56 PM. Reason: Automerged Doublepost |
Yeah cause Nissan decided to F with it and make it weak.
