Ya I used rustoleum wheel paint. I sanded it down and put 3-4 coats of that stuff on each wheel. It holds up pretty good. I've wheeled multiple times and only have a couple of small chips. The majority of the blemishes like you guys said are inside the lug nut wells. But other than that I am very happy with the wheel paint(rattle can). Didn't want to use plasti dip cause I was afraid it would peel easy. But I've heard some good things about it! If you go heavy on the plasti dip you should be fine.
Sent from AutoGuide.com Free App
