Hey one of those trucks in the pics above is mine ... LOL
I am fairly certain the OP was looking for pics with the newer style pro-4x rims with 285's , like in the third pic (Xterra Snow) posted above.....
Yes BCBrians , somewhere around 2013 or 2014 nissan starting putting those newer style rims on the Pro-4X frontiers and xterra's.
Thats why I was trying to point the OP to a pic of Nomad13's truck before he added a titan swap to his drop bracket kit and 35"'s with aftermarket rims
I see you got a pic of Jen's truck and Shizzy LOL
Those all look so good - makes me kind of look forward to when the tires that came on mine (original Hankook's) wear down so can replace them! However I hope to get a lot of tire wear out of them - dropping $35k on a truck kind of sets you back
Just thinking out loud....
Put a low priced spacer lift in the front and lift shackles and or add a leaf in the rear get some 285's and sell your 265's on craigslist while they are still like new.
I have sold tires on craigslist twice now and they sold with in an hour after posting.
This is my '14 Crew Cab on stock Pro4X wheels with 285/75/16 Hankook Dynapro tires. The truck does have a lift, so no real serious rubbing, but there was a little bit...which was easily mitigated.
Kept the same front shocks. I did neglect to mention that I had to replace rear shocks with extended shocks from PRG. The Bilstein 5125. After adding the shocks, block and AAL...the ride is better than stock.
Goodyear Wrangler Duratrac 285 75 16. Rear suspension is a custom hybrid leaf pack using a combination of the Deaver AAL from PRG and a extra leaf spring from another set that I had. Fronts are adjustable Radflo's and PRG upper A arms.
Here is a closeup of a 285/75-16 DuraTrac on the newer PRO4X wheel and the full image of my avatar. While the sidewalls do bulge slightly, they are wearing very evenly. I run them at 36PSI on the road and 17-18 off road.
It's no problem. I have been running these Falken Wildpeak M/T LT285/75R16 for 50k and aired down many times in the dunes. They say that extra tension is good if you are aired down.
