I'm able to get 4 free winter tires of size 235/75R15 for my PRO-4X. I know the base Frontier has that size of tire but is there known problems for using this on the other Frontier?
235/75-16 is a stock size? For what.... 2WD? Stock size for the Pro4X is 265/75-16
There will be a few issues...
- Ground clearance will be reduced
- Speed and ODO will be WAY off
- Stopping distance may be increase
- It will just look weird
__________________ 2010 SE K/C V6 4X4My Truck Build Armor: Hefty 5 pc Skid Plate set. Shrockworks Sliders. Blue Torch Fabrication Differential Cover. Suspension: PRG UCAs with 2.5" Radflos and 650 lb springs. Bilstein 5125s with Deaver AALs. Wheels and Tires: Stock SE Alloys with Hankook Dynapro ATm LT265/75-16.
the pro4x is sooo special and unique, there is no way anything that would fit on a cheap regular frontier would ever fit on the mighty pro4x.
i wonder when these pro4x owners will get off their superiority chair and realize the pro4x does not in fact use super special unique top secret parts. a weird concept but since the two trucks are indeed identical for the most part, parts are indeed interchangeable.
The Following User Says Thank You to zoomzoom For This Useful Post:
If you are reusing rims already on the vehicle that size tire will probably work, but it will be pretty small. You will want to check the load rating for certain, and snow tires tend to be a bit squishy to begin with.
I have 245/75R16(111S) snow tires on my truck and they have a lot more sidewall squirm than the stock 265/70R16 (111T) tires. They're quite a bit more squirmy than the Cooper ATPs I run in the summer as well.
No frontier has that tire/rim size you have listed. And unless you have an extra set of rims a 15" tire won't fit on a 16" rim (which is stock on the frontier)
2010 pro 4x CC - Calmini Rear bumper, 3 fin m205 with cardone titan axles, PRG SAW titan swap pkg with remote res and 650 springs, PRG Shackles, Bilstein 5125 ext travel rear shocks and PRG 2" deaver AAL, 255/85/16 km2's, Hefty Skids and sliders, TJM Portable Air compressor, and 20" Alien LED lightbar.
Next on the list - Shrockworks or Calmini front bumper with winch
I hate argue with you humz but the King Cab S 4 X 2 has exactly that size of tires.
The truck is 2012 and no I do not have the rims, in fact I can get the tires for free that is why I was interested. I know the that the size is quite a ways from my PRO-4X 265/75R16
Reason: Automerged Doublepost
It's 2012 King Cab Pro-4X. No I do not already have the rims it's the fact that I'm able to get the tires free (and the rims) that got me asking questions. Honestly I'd rather have same size winter tires but when the price is right one should look into the opportunity, right?
a stock XE frontier comes with thats size thats what the sticker inside my cab says
WHEELS 265/75 16 general red letter level 8 zx with rock gaurd
SUSPENSION bilsten 5100 with ac coils prg aal
BODY custom black out grill tinted tall lights and tinted 3rd light and blacked out inside of the head lights tinted windows
INSIDE alpine type r 6.5 and 6x9 Pioneer AVH-P4400BH arc audio arc series 12
PERFORMANCE dt long tube header with 2.25 inch custom exhaust with a dynomax muffler
Actually, the Pro-4x (along with every other V6) does indeed have super special unique top secret brakes. I'm 99% positive you can't fit a 15" rim.
