did you find the problem yet?
Have you checked for a spark at each plug? If not work your way back through the ignition system. If you do check the fuel system, although I don't think a fuel problem would throw that code?
2000 Crew Cab 4WD 6cyl 3.3, Alpine audio, Nismo cat back, ks relocate, Falken Wildpeak A/T 31x10.5, Weathertech, Bilsteins
Reason: Automerged Doublepost
