1st and last Nissan - Page 2 - Nissan Frontier Forum
post #11 of 47 (permalink) Old 10-14-2016, 09:24 PM
TAGS's Avatar
Quoted: 106 Post(s)
TAGS is offline
post #12 of 47 (permalink) Old 10-14-2016, 09:48 PM
R00
R00's Avatar
Quoted: 249 Post(s)
#shitforgrounds
R00
a.k.a. MakTruk
Overland Bound #0912
"Enthusiasm is a dangerous replacement for experience." -- BCBrian
R00 is offline
post #13 of 47 (permalink) Old 10-14-2016, 09:49 PM
Blue Devil's Avatar
Quoted: 375 Post(s)
So you came from a 10yr old car, and say the seats feel so much better than that?
What 6 trucks have you owned that handled and drove much better than a 2014 Frontier? Please list them for my curiosity.
Those late 1990's Ford Rangers sucked a@@ I drove a couple of my friends talk about slow and carppy.
2006 Nismo KC, 6spd, bought new Dec.2005, 142k 99.7% trouble free miles, never left me stranded Denso Iridium Power plugs, Gibson 612211 SS catback, modded with a Magnaflow muffler, XTP IMS, FIPK series 77 K&N intake, CSF radiator, Romik bull/side bars, Bilstein 5100's rear +Firestone riderite air bags, PRG aluminum diff cover, PRG rearend vent mod, Rancho Quiklift front shock/spring combo, MOOG front hubs, StopTech drilled/slotted brake rotors, Spyder CCFL halo headlight assy with Innovited 55W HID xenon H1 conversion kit, OLM HP Gen2 passive cooling LED fog lights, Weathertech window visors, Bridgestone Dueler AT Revo2's P265/75/16 114T .
Blue Devil is offline
post #14 of 47 (permalink) Old 10-14-2016, 09:56 PM
R00
R00's Avatar
Quoted: 249 Post(s)
What's funny is the Frontier generally gets better marks in handling than other midsize trucks in its class. It's why we have such a hard time lifting them without CBC and control arm issues. Also why they have the turning radius of a greyhound bus.
R00
a.k.a. MakTruk
R00 is offline
post #15 of 47 (permalink) Old 10-14-2016, 10:03 PM
R00
R00's Avatar
Quoted: 249 Post(s)
Also, your "battery gauge" isn't really measuring your battery voltage (well, ignition on, engine off, it is) it's measuring voltage *at* your battery. If your "battery gauge" is "reading low" while the truck is running, that means your alternator is putting out insufficient voltage to the battery. It could also be a voltage regulator, but I am unsure if the regulator is internal on our alternators.
Also, good to note is that after 2008 or so, the needle gauges in Frontiers and Xterra don't read true. There's only "low" "normal" and "OH **** TURN IT OFF!!!"
Pull the alt and take it to a shop and have them bench test it. Chances are it's on its way out. Not unheard of.
Of course, if that's the issue, we will probably never hear from you again, lol
R00
a.k.a. MakTruk
R00 is offline
post #16 of 47 (permalink) Old 10-14-2016, 10:27 PM
raine's Avatar
Quoted: 490 Post(s)
Originally Posted by Trouper View Post
1. It's not from leaving a light on, it only happens when the truck gets wet and it has happened multiple times in the last month.
2. There's a lot more to testing an alternator than checking voltage, amperage has a lot to do with it and I have no way to test that much less to do it while everything is wet.
3. No it doesn't drive like a truck, it drives like a POS. Everyone of the 6 other trucks I've owned have handled and driven better.
4. Tires are at 32psi, but let's not get started on that because the stock tires are horrible and will be replaced before winter if the truck isn't replaced.
5. Yes I sat in the seats, but when you go from a 2006 car to anything brand new it's going to feel better.
6. Sorry to hurt all your feelings about your beloved Frontiers but I'm not impressed. If Ford still had a Ranger I never would have given Nissan a thought.
I'm sorry if you've had bad luck with your particular vehicle and whatever dealership you went to... maybe find another dealership that will help?
GLHF That said - no apology needed, you're welcome.
- Raine.
"...doesn't look like anything to me."
click above for my build thread
TYPE CREW CAB SV 4x4 COLOR NIGHT ARMOR LIFT 3.5"/2.5" NAME KEIRA
SUSP: Custom King Shocks . Total Chaos . Level-8 . BF Goodrich . Deaver . Nisstec . Bilstein . PRG
EXT: White Knuckle . PIAA . Truxedo . White Rhino . Firestik . Morimoto . Mitsuba . Evoc . BlueSea
A/V: Hertz Audio . JL Audio . Kenwood . Alpine . Dynamat . Fr/Rr Cameras
MODS: Power Tailgate Lock . Custom CB Antenna Mount . Trailer Plug Relocate . Diff Breather Mod
MORE: Midland . UltraGauge . Raingler . Working OEM SWC, Bluetooth, USB . Some Stickers
raine is offline
post #17 of 47 (permalink) Old 10-14-2016, 11:07 PM Thread Starter
Quoted: 7 Post(s)
I've owned a 1981 F-150, rode and drove like ****, it was 16 years old at the time. 1986 Chevy 1/2 ton 4x4, also junk these wherefiret couple vehicles as a teen. 1995 Ranger, 1997 Ranger-best vehicle I've ever owned, 2000 Ranger- was a turd but rode decent was reliable and made me a lot of money, 2002 Ram 1500 4x4-good truck with bad wiring, 2004 F-150-awesome truck that handled the curves and bumps like a champ and would pull anything I wanted, and a 2007 Explorer Sport Trac- gas hog but otherwise good vehicle. I've also driven several different trucks for work plowing snow. I'm not new to trucks! Not new to vehicles! I've also been to school for Engine machining and know how to turn a wrench. Ultimately this issue has been a failure on TWO separate Nissan dealerships that don't want to support the vehicles they sell. As I said I wasn't impressed before this but it wasn't the hatred I have now. My truck gets compliments, it looks good and it has pulled well over it's 6000 lb rating. But when a vehicle with less than 30k miles on it has been to the dealership more than once for the same problem and they don't want to know anything about it. It leaves a bad taste in my mouth. When I bought the truck I was in a bad place financially and the dealer worked with me to get it, so I went from a 2006 Subaru Impreza with seats not made for a bigger guy to this Nissan. The seats obviously felt great at the time. I'm not the only one complaining about them. My whole family hates them and I'm not the only one on here to complain about them either!
Maybe I came off with a bad attitude but damn people, I was hoping for more insight on the problem at hand. A few people actually have seen that and offered up bits and pieces. I do feel the alternator is on its way out. But when my truck is under warranty why should I have to pull it and pay for it? On top of that Nissan had to be stupid and put it down low where it's difficult to get at.
Trouper is offline
post #18 of 47 (permalink) Old 10-14-2016, 11:17 PM
R00
R00's Avatar
Quoted: 249 Post(s)
In my experiences with dealerships (and for this truck, there wont be any more, my service contract ran out 5k ago) you have to specifically tell them what you want addressed, or they'll do the diagnostic runaround and it'll take forever. Walk in, tell them the alternator isn't putting out sufficient voltage (again, verify this with a voltage meter, reference my comment on Nissan dummy gauges) and that you want it bench tested. Pretty simple. As long as you know what you are talking about, you'll win any debate the service mgr. throws out at you.
If they do anything else, a) you're not on the hook for it, since you didn't ask for that and B) now you can forward your complaint up the line and get something done.
Nissan dealerships are dealerships, not Nissan corporate. One does not necessarily look out for the other.
R00
a.k.a. MakTruk
R00 is offline
post #19 of 47 (permalink) Old 10-14-2016, 11:42 PM
mtyler11's Avatar
Quoted: 268 Post(s)
First off, you have some $hitty dealers in your area. But considering my experiences in central NY, you'll want to go Upstate or (more likely) out of state. Really, they're just shitty dealers. No dealer in their right mind that WANTS to keep you as a customer would tell you that your problem is due to a trailer brake controller. As for the loaner, diagnostic should be under an hour, and for that I have never seen a dealer give a loaner. There's a Hyundia dealer that I love, took care of so much under "warranty" (several of the items shouldn't have qualified, but they 'made' them qualify) and unless they KNEW they would need the car for the day, I had to wait for the diagnostic. Once the diag was done, key in hand for the next filming of Days Of Thunder. Even when I had an intake manifold failure and it had NO power and could barely idle, they had to verify it wasn't something quick & stupid. Took them 30 min to verify. So your biggest issue is dealer.
As to the actual problems with the truck (electrical). It happens. I had a few minor issues with the truck when I took delivery. Mostly with things the dealer was supposed to do when it arrived off the delivery truck. To test the amperage of the altenator all you need is a clamp ammeter. safe & easy. can do it wet or dry. you can get one from Harbor Freight for $12. Or just ask the friendly Autozone guys to test your battery & altenator. And while the rear can be a little jumpy when its empty, thats because its an empty truck. Every truck I've had has done that. My father's 2008 F150 does it and that sucker is long & heavy. It also handles worse than my Fronty. He even thinks so. BUT he is a Ford man and needs to tow a 32' travel trailer.
If the fabric of the seats is an issue, a cover will fix that. I tried both Nissan & Toyota and fabric-wise they were both the same (I drove the Toy to the Nissan dealer and had them side by side... lol... watching the 2 salesmen... AWKWARD!!!!) But I didn't like the seating position of the Toy. Or their attitude of "we sell out every month, we don't have to dicker on price" Almost as bad as "its a Jeep thing" Plus, if all you did was go from your old worn out seats to the Frontier and called it good, thats on you. I spent several months looking at prices & options, then several months test driving multiple brands & models.
Oil filter is not that difficult. And you're not supposed to reach up through the access port, thats for the oil to come out of. You flank it from the side... in a sneak attack! (no seriously, you reach in from the side)
Tires: everyone knows (including Nissan, which is why they started offering Hankook) the BFG LongFails are bad. But, they are cheap (for them in bulk), and get good mpg which is what nissan needed them to do.
I hope you find a good dealer or mechanic (an independant can do warranty work also, AND get paid by the mfr. They just have to be willing to do it. Most won't because its a hassle. The dealer does it because they are forced to). I felt the handling was 'wierd' too at first; I was coming from a small car - that's why. The bulk of your handling issues will be corrected by tires & shocks. Even the Pro4X stock shocks will be a noticeable improvement, but if you do that, may as well get hte Bilstein silver bodies (5100) BUT a Good dealer may give you a set of yellow Bilstein (stock P4X) for labor. Particularly if you are telling them of the issues you have and are looking to replace your tires but can't swing shocks... this would come after they have fixed the electrical (because now you have begun a 'relationship' with them and they want to earn business)
- - Illegitimi non carborundum - -
- - 2014 SV 4x4 V6 Auto - - F.O.R.C.E. - - ExploringNH.com
-build thread- stomper
[gone] 76 GMC Sierra 4x4 RCSB -383 v8, SM465, 3.73:1, TT rear, Dana44 & GM12bolt c-clip converted
[gone] 85 RX-7 5spd
[gone] 79 F-100 2wd
mtyler11 is online now
The Following 2 Users Say Thank You to mtyler11 For This Useful Post:
ahinalu (01-11-2017), Zedbra (01-08-2017)
post #20 of 47 (permalink) Old 10-15-2016, 12:11 AM
mtyler11's Avatar
Quoted: 268 Post(s)
mfr & dealer are independent entities that are actually at odds with eachother. The mfrs would actually rather sell direct to buyers. They'd make more, we'd spend less.
SHOULD you have to fight with the dealer? no. But that is the problem with dealers. If they feel they have a monopoly and don't have to earn your business, they won't. If you go to other service cntrs or independents and discuss your issue, they may be willing to fight the fight for you. dealer service centers from competing lines often will work harder to win your business and trust in hopes you'll dump your old vehicle for one of theirs.
[gone] 85 RX-7 5spd
[gone] 79 F-100 2wd
  Nissan Frontier Forum > Nissan Frontier Forums > New Member Introductions
You may post new threads
You may post replies
