Go Back   Nissan Frontier / Navara Forum > Site Sponsors > Hellwig Products
  #41 (permalink)
Old 09-02-2008, 08:38 PM
Dave@Hellwig's Avatar
Shift_Site_Sponsor
It does transfer weight, but it cannot solve a traction condtion caused by a slippery road surface.
  #42 (permalink)
Old 10-15-2008, 03:35 AM
Devius1's Avatar
Ehhhh....Wow!
Got-it....
The install was pretty straight forward after calling a tech. (Dave) I made the instructions more complicated; everything is where it should/could be.. was kinda iffy about drillin' 11/16th'' hole through the outside frame to accomodate the steel sleeve tho'. (welding optional)
Didn't even take a wheel/spare tire off.. and it's very adjustable.
I've got a "urban Nismo" so a rear sway was a good idea.. first driving impression was Ehhhh.. it's not all that; decided to adjust the "angles" I choose for the install (short links/bar back = more clearance) to longer links (adjustable) + "squared" the bottom mount... Wow! Understeer and rear slop was dramaticly reduced; sorta drives like a big car, less front push and getting rear pull.
I LIKE IT! some more tuning to find the sweet spot and it's all gravy.
2/08 prod. 4x2 KC Nismo
Borla-Energy Suspension-Escort-Hella-Hellwig-Madico-NISMO-Piaa-RAZO-Royal Purple-Shrockworks-Truxx-UNGO/DEI-WhiteRhino
  #43 (permalink)
Old 11-07-2008, 11:07 PM
MJR's Avatar
MJR MJR is offline
Originally Posted by Dave@Hellwig View Post
Regarding the offroad capability of this sway bar, it really depends on what you are doing. In most moderate off-road applications the bar is a benefit. The only drawback to having a rear sway bar would be if you were rockcrawling as it does limit articulation.
I think the question was issues off road not the durability of the bar/end links themselves. I like having a sway bar and as so need some way to be able to disconnect it for off road. But as one who uses or plans to use my truck off road the real problem I see is simply the way/location of the sway bar. It would have to be mounted behind or above the axle so as not to interfere with ground clearance which is most important off road, thanks.
'06 NISMO KC 6spd
Work in progress
  #44 (permalink)
Old 11-13-2008, 07:08 PM
Shift_Site_Sponsor
In its current installation it is no lower than the shock brackets. The brackets can be rotated rearward to move the bar up. If your vehicle is stock height the end links may be too long but we can provide a shorter lower half to make up the difference. If you have a lift then it would be no problem. Just watch for brake lines, etc.
  #45 (permalink)
Old 11-13-2008, 11:23 PM
sleepy23's Avatar
any special pricing coming up again?
Performance: WRP: CP/Grounding Kit/IMS/PS Pulley, AEM BF CAI, TB Grounding, TB Mesh Removal,TBS, E-Fans, Optima 35R,Nismo S-tune Exhaust, Nismo 18's on Nitto 404, TBIC, Nismo thermostat, UpRev Tuned
Exterior: Roof Rails,Smoked Euro Tails,5k HIDs & Fogs,Fog Light Mod, Painted Engine Covers, Nismo Tailgate Badge, 20% Tint, Nismo Radiator & Reserve Caps, Nismo Oil Cap, Redline Tuning Hood Struts,Smoked 3rd light, EZdown, Color match head lights/grill/tailgate finisher, Custom Badging,Red calipers,door mouldings
Interior: RF System, Nissan IPOD,Al pedals,Color Matched switch covers, Homelink, LEDs,custom shifter,HVAC Overlays,Auto down windows
To Do: Custom Overlays, swaybar & more
  #46 (permalink)
Old 11-16-2008, 04:39 PM
shinermiller's Avatar
Shiner Wants... Dave @ Hellwig, Shiner wants Info!
your fastest SE CC Auto 4x4- Uprev Tuned ECU
14.506 @ 93.10 mph
http://www.youtube.com/watch?v=bTz2PTYwmnU
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jaxpayne
