Go Back   Nissan Frontier / Navara Forum > Site Sponsors > Discount Tire Direct
  #41 (permalink)
Old 08-18-2008, 07:24 PM
jalmquist75's Avatar
That tire is 1/2in taller, I like that, but is it too wide for the stock rim? What advice does discount have? I am 10 minutes from calling them to order?
Jay
Big J
  #42 (permalink)
Old 08-18-2008, 07:47 PM
Discount Tire Direct's Avatar
Shift_Site_Sponsor
Originally Posted by jalmquist75 View Post
I have a 2005 Nissan Frontier King Cab LE, 4X4, V6. I have a two inch lift kit, taller springs up front and taller shackles in the back. Currently have 265/65R17 on stock LE rims. I do about 50/50 highway/city. Once a month I go camping and mild offroading, mostly sandy trails and some river rocks. I think these tires measure about 31"? I really don't like the look of the small sidewall and would like a tire of about 33". I am pretty sure they won't rub or anything. I have no clue what size to get and am not a big fan of aftermarket rims. Can you advise?
Thanks
Jay
Thank you for your patience Jay, I have been slammed for questions today. Sorry for the delay.
You might be able to get away with the 285/70R17 but you would need to test fit. Your optoins in this size are going to be limited though if you don't want a stiff ride. Kumho makes the KL78 in a P petric version (4)ply that would be awesome on there for you. Most of the other tires in that size are LT tires and are going to ride stiff because they are 8 and 10 ply tires.
The 285 will fit your 7.5" stock wheel fine but you don't want to go any wider. If you are going to rub it will be at full lock. Here is a tire size calculator so you can see the difference, look under your truck and see if you have the clearance. Tire Size Calculator
Kumho KL78
All: 285/70R17 *sizes with E = 10ply D = 8 ply and C= 6 ply.
Originally Posted by Californiaboy View Post
damn your just getting slammed with questions!! Im picking up some 295/70R17 terra grapplers tonight! they will fit stock, but im hoping i can get some procomp 7189's under there
What's the exact year make and model of your Frontier? Do you have a lift? What offset are you going with?
We guarantee the lowest delivered price for tires and/or wheels on the web. We'll do our best to match or beat the competition. We offer free mounting and balancing on packages, and a 30-day satisfaction guarantee! We also offer the industry’s best warranty, and no, it's not pro-rated. Purchase our certificates and if anything goes wrong for the life of your tire, we'll replace it for FREE.
1.888.459.4080
www.discounttiredirect.com
www.myspace.com/discounttiredirect
  #43 (permalink)
Old 08-18-2008, 08:03 PM
Shift_Site_Sponsor
its an 06 kc with a 3 inch Calmini lift. what should i go with?
Looks like the make them in a 17x8 with a 4.5" Backspace (0mm) offset. If you went with that size with will stick out about 1/4".
In comparison to the stock option 17" wheels and tires the 295.70.17 is 2.7" taller in overall diameter. See calculator in two posts above. You are going to want to test fit this. Chances are, you will rub. You also might want to consider the 285.70.17 to minimize the chances.
1.888.459.4080
  #44 (permalink)
Old 08-18-2008, 08:09 PM
Shift_Site_Sponsor
Awesome. The 4.5" BS will be your best bet. Send me a link when you post pics. It should look great.
1.888.459.4080
  #45 (permalink)
Old 08-18-2008, 08:14 PM
mdawg4x4's Avatar
What is the reason for limited wheel selections for the 05+ Frontiers/Xterras/Pathfinders?
Limited bolt pattern use? I think the Dakota shares our pattern?
Brake clearance?
I see many available for 5 on 4.5 (Jeep TJ pattern), but few for 6 on 4.5.
06 NISMO CC 4X4: AC Deluxe Lift w/Rancho RS9000Xs (until I can go PRG Radflo technology), Alpine CDA-9857 HU, Alpine Type R 6.5 components in front, Type R 6.5 3-way in rear
Other Rides:98 Jeep Wrangler 2" spring spacers, Rubicon coils, Borla Header/Flowmaster, 33-12.50 BFG MTs on 15X8 MT Classic Lock;
Wife's 05 Pathfinder SE Off Road (but only 4X2)
  #46 (permalink)
Old 08-20-2008, 03:58 PM
Thanks for the reply. I went with the BFG ATko 285/70R17. It rubbed on the front mud guard and front inner wheel housing. An hour with a dremil and I have about 2in clearance. I will post picks. The tires looks great on the truck, are quiet, and it rides nice. The tire is stiffer but taller so the ride is actually a little smoother. You can notice the weight difference a little bit also. I would not advise anyone to go bigger unless you have a 5" lift.
Big J
  #47 (permalink)
Old 08-20-2008, 05:28 PM
Shift_Site_Sponsor
ill send pics once im done. you ship to cali right? god i hope they fit, or im skrewed.
We ship all over the US and Canada.
Brake clearance?
There are very few vehicles with the same bolt pattern as the Frontier it is a 6x114.3. I am pushing our wheel department to offer a few more designs for you but it will take a little time. Some of you know I am in the same boat as you guys. My wife has a Frontier and I have been looking at wheel options for a while now and there just aren't that many. I hope to help with that. (Fingers crossed)
Awesome and good work. A little modification and I bet it looks great. Pics?Pics? pics?
1.888.459.4080
  #48 (permalink)
Old 08-22-2008, 01:33 AM
Hub-centric rings
I recently purchased a set of 20in LiquidMetal Magma rims from your site. They look awesome but at about 45 or higher they vibrate like crazy i've gotten an alignment and balanced them. My next step is hubcentric rings can you give me the dimensions for a 2007 Frontier KC SE, with 20in Liquid Metal Magma rims. Does this sound like the problem?
  #49 (permalink)
Old 08-22-2008, 02:23 AM
CoryRBM's Avatar
Send a message via AIM to CoryRBM
Any chance of you guys carrying the MB Express wheels again?
'07 SE CC LB Red Brawn
Rest Easy Britt.
12/11/07
  #50 (permalink)
Old 08-22-2008, 02:37 AM
Wyldcat89's Avatar
^^ there is a set available in the For Sale section! Grab 'em while you can, great looking wheel.
I have one other question and I think I'll be good to go. Do you still have the capability to get the MB Motoring 72's in the black/silver, 17x8, for our bolt pattern (6x114.3)???? I see the polished versions up on your site but not the black set.
