Details:Nitto Dura Grappler For a 33x11.50-16, it is recommended by the manufactures to run that size on a 8" wide wheel.
We guarantee the lowest delivered price for tires and/or wheels on the web. We'll do our best to match or beat the competition. We offer free mounting and balancing on packages, and a 30-day satisfaction guarantee! We also offer the industry’s best warranty, and no, it's not pro-rated. Purchase our certificates and if anything goes wrong for the life of your tire, we'll replace it for FREE. 1.888.459.4080 www.discounttiredirect.com www.myspace.com/discounttiredirect |
so 10.50 is the widest you would suggest i should go then...rats ok ill have to either deal for now or buy new wheels
05 CC Frontier Nismo 4x4 Weld It, Grind It, Paint It, Pimp It!
[quote=Discount Tire Direct;494676]The 265/75-16 would be a great choice. Here's what I would recommend for a good all around tire.
Details:Nitto Dura Grappler Thanks for the info. I am also confused about the tire measurements. I see some tires with the above type of measurement, then i see some with 33/10.5/16... seems to be a metric/inches thing... What tire would be the same as the 265/75/16 in inches?? and what would fit my nissan/06/cc/2wd/stock rim... thanks again Brett |
Tire Size Calculator
This link will help you a lot. You can put in any size and compare it to stock. It will tell you how much the change will effect your speedo as well.
Hey DTD, bought my wheels and tires from you guys( MB Predators and Nitto Mud Grapplers and 4 TPMS's). Have had the tires and wheels on my truck for little over a week now and this weekend my TPMS light came on and tire pressures are good. Light won't go out. What do I do?
06 KC RED NismO 4X4, 3" bodylift, K&N CAI 63 series, tow package, ventshades, bug deflecter, sirius, tonneau cover, RealTree seat and steering wheel covers, 1200watt Cadence Amp and 2-12"Pioneer subs, JBA Ceramic coated Headers, and JBA SS catback exhaust, 3M 35% tint, 6" Fabtech lift, 17x8 MB Predators, and 35x12.5x17 Nitto Mud Grappler's. More upgrades to come!
AIRBORNE! |
If you bought new sensors you will need to have the new sensor ID's entered into your truck's computer, any retailer with a TPMS scanner will be able to do this. If you have already done this, double check the air pressure, temperature and elevation can effect your pressure enough to kick off the light. Resetting the pressure should turn the light off.
help
I need a 285/75/16 set that is aggressive but not to rough riding. I dont want to spend an arm and a leg either. Gas is bad enough. I have always run Pro-Comp on my trucks but the MT gives you a bumpy feel after about 5000 miles on them. They are a great tire but I want something different for this truck. Its my daily driver and I want the ride to be smooth but I still want an aggressive tire for when I do decide to lock her in and roll through the trails.
Here's what i have used in the past Maxxis buckshot ....ok Pro-Comp Mud Terrain ...great offroad but a little bumpy on road Pro-Comp X-terrain ....smmoth at first but rough with wear. great offroad BFG MT ....great on my light weight 72 Bronco. Too expensive Goodyear Wrangler MT ...hate em Mud King by BFG ...not bad for the price |
Awesome question. Thank you for the details. A few things. The 285.75.16 size is full of 8 and 10 ply tires. They are going to run a little rougher than your stock tires no matter what tire you choose. To keep an even wear on 8 and 10 ply tires you generally have to put more pressure in them. As for some suggestions, have you looked at the Nitto Terra Grapplers? ![]() For a daily driver the Terra Grappler is very smooth. They also look really nice and will take you offroad when you need them too. THey won't hurt your pocket too much and you should be able to get some pretty good miles out of them if you rotate and maintain the correct pressure on them. link: Terra Grappler. The BFG TA KO would also be a great tire for you but they are a little more money. They are very smooth on the road, you will get a lot of miles out of them and they are great off road as long as you don't spend a lot of time in the mud. link: BFG TA KO
