Closed Thread
Old 06-25-2008, 02:20 PM
Inyourface1650's Avatar
What Axle/Gears do I have?
Ok, so there is a helluva lot of confusion and misinformation out there about gear ratios and axle housing types per truck, so I am going to try and lay it all out here.
people Let me know if I made any typos.
There are two Types of Axles, C200 and M226(D44h).
Rule of thumb is NISMO and 6-speed models have the D44. But apparently this is way to complicated for some people, so here it is broken down
Model Axle Gears
XE KC 4x2 5M C200 4.083
XE KC 4x2 5A C200 3.692
SE KC 4x2 6M M226 3.538
SE KC 4x2 5A C200 3.133
SE KC 4x4 6M M226 3.538
SE KC 4x4 5A C200 3.133
SE CC 4x2 6M M226 3.538
SE CC 4x2 5A C200 3.133
SE CC 4x4 6M M226 3.692
SE CC 4x4 5A C200 3.357
NISMO KC 4x2 5A M226 3.133
NISMO KC 4x4 6M M226 3.692
NISMO KC 4x4 5A M226 3.357
NISMO CC 4x2 5A M226 3.131
NISMO CC 4x4 5A M226 3.357
LE KC 4x2 5A C200 2.937
LE KC 4x4 5A C200 3.133
LE CC 4x2 5A C200 3.133
LE CC 4x4 5A C200 3.357
Please note that the gearing may not be accurate for LWB models, the specs I am using do not include LWB, so I do not know if they are geared lower to make up for the weight increase. However, the axles will be the same
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
ONAZ
The Following 7 Users Say Thank You to Inyourface1650 For This Useful Post:
06_footy (10-23-2008), 07Frontier (06-25-2008), bigfloppydb (06-25-2008), HoSeHeaD (10-23-2008), MrEd (06-25-2008), Pro2X (08-20-2008), RaginRabbi (06-25-2008)
Old 06-25-2008, 06:13 PM
bigdog's Avatar
So, I've been doing some research on this subject and attempting to find out what options do exist on the C200 as it relates to gear ratios. I think I've finally found what I was looking for. It looks like you can buy a replacement gear set from Nissan for the C200 Rear End, and change your final drive gear ratio. There are only a couple of options so you may not get where you want to go, but for some of us this may be an options.
So here are the facts on the gears in the C200 rear end:
Model - Gear Ratio - Number of Teeth (Gear/Pionion)
QR25DE KC M/T 4x2 - 4.083 - 49/12
QR25DE KC A/T 4x2 - 3.692 - 48/13
VQ40DE KC A/T 4x2 - 2.937 - 47/16
VQ40DE CC A/T 4x2 - 3.133 - 47/15
VQ40DE KC A/T 4x4 - 3.133 - 47/15
VQ40DE CC A/T 4x4 - 3.357 - 47/14
What this means is if you've got a 4 cyl. KC M/T then you've already got the deepest set of gears Nissan has for this drive, but for everyone else on the list it looks like you've got at least one set of gears to switch to. On courtesy parts these gear sets go for about $500, but you may be able to find a used set for less. I am not sure if you will need to replace the differential case or not (it looks like there is a 4 cyl and a 6 cyl case) or if the dealer will do this work for you. But I called my local dealer to get this information and we seem to be heading down the path of them doing the work.
For me it looks like I can go from 3.357 to 3.692 or 4.083 Now if you use a calculator (like the one at 4Lo.com) you can determine what your new gear ratio should be to compensate for your bigger tires. For example if I were to go from 30.5" to 32.8" tires the new gears should be 3.61:1 and Lo gears (e.g. for rock crawling) would be 3.94:1. So this seems to tell me that for my "new configuration" I should go to the 48/13 gears (3.692) out of a 4 Cyl A/T and I'll be back to an optimal setup. Otherwise my effective ration will now be 3.12:1
NOTE: If your model is not listed here, then you've got the other rear final drive and I did not get the specs on that.
2006 SE CC 4x4 A/T:
Old 10-23-2008, 04:54 PM
igbar's Avatar
SHIFT_Senior Moderator
I moved all the questions and chatter to their own thread to clean up this sticky.
Regarding the "What axle/gears do I have?" thread...
This sticky is now Info Only.
Closed Thread
HTML code is On
