| The Following User Says Thank You to mike For This Useful Post: | ||
06_footy (07-14-2008) | ||
yeh dont blow that
If Matt didn't give me such great deal I would still have the M180.
The biggest advantage in doing the titan diff swap is for the titan suspension swap guys. You get a better front diff along with the right size axles, for the same price as replacment axles. If you are an auto the titan comes in both gear ratios so you will be fine.
rerlandson, from what you said, does that mean that I can't do a PRG Titan UCA and Titan LCA mod without first installing the Titan front diff? I don't think that is what you meant but I need to ask to clarify.
![]() '05 Nismo CC: Banks Monster Exhaust (Sound clips), Pioneer Avic-D1, Raffle Volant CAI, Stryker SR-490, Stryker antenna, Kumho Road Venture A/T's, Shrockworks sliders, Fabtech 6" Lift, Revolver Shackles, AAL's, Snorkel. The fox will never keep the hen-house safe! NObama! Obama a natural born citizen or an Indonesian Muslim? Obama Does Not Have a US Long Form Birth Certificate and Why What were the Crusades all about? -Peter Hammond The word "crusade" is not found in the Bible or commanded and the Crusades ended over 7 centuries ago. Jihad is one of the pillars of Islam and is commanded and still goes on today! |
You can, but then you have to get extended axles for the front diff. If you do the titan swap, and put in a titan front diff, you only need to get titan axles.
Well Greg told me he has the kit for the Titan control arm's swap with the custom axle shafts and tie rod extensions. I didn't think about this before but maybe I need to ask him if thos custom axle shafts are intended for our stock front diff or the Titan front diff...
you dont need custom axle shafts for the titan diff........you can use stock ones. so its for the Frontier diff
Oh ok. So are "axle shafts" and "half shafts" the same thing? Because I've picked up this much from Mike that the Titan front diff swap requires, ofcourse, the Titan front diff and "pathy half shafts".
