Old 07-09-2008, 01:00 AM
Servinhimonly's Avatar
Titan Front Diff Swap
And here I was thinking that a Titan front diff swap on my Frontier would be another check on my list of things I wouldn't have to worry about breaking on the trail...
SURVEY: Front Differential Problems - Nissan Titan Forums
Old 07-09-2008, 01:03 AM
Inyourface1650's Avatar
And....titans have over 100ftlbs of torque and like what? 800lbs on us?
Yeah, they break em all the time.
1994 Pathfinder Auto 4x4. Mall Crawler.
2007 NISMO KC 6M 4x4 - Gone
2005 SE KC 6M 2x4 - Gone
2002 SE CC 4A 2x4 - Gone
Old 07-09-2008, 01:30 AM
mustard23's Avatar
the dif will swap in and bolt up put you can't mach front and rear gear ratio
I had jack ball and weinersnitchel weiner antenna topper stolen from my truck.. so screw that I'm not moding it anymore
Old 07-09-2008, 01:59 AM
igbar's Avatar
SHIFT_Senior Moderator
even if we have the M226?
Old 07-09-2008, 02:04 AM
mustard23's Avatar
i know that is why nizmut took his titan front diff out, the defrence was to big.. but if your going to swap gears on the m226 then just swap the rear axel also.
Old 07-09-2008, 07:05 AM
mike's Avatar
I have the M226 (frontier) rear and the M205 (Titan) front. Both have3.3 gears.
Old 07-09-2008, 07:13 AM
Mainerunr's Avatar
the mut had (has?) 3.69's like I do, the auto guys should have no problem (3.357's), it's the manual nismo and SE guys (with 3.54's and 3.69's) who can't match what we have.
Old 07-09-2008, 12:15 PM
mustard23's Avatar
I forget about the auto guys..
Old 07-09-2008, 01:13 PM
Well I read that the Titan front diff has been redesigned but don't know what year the redesigned model is. But how are we to know that the problems the front diff has in the Titans aren't going to exist when installed in our Frontiers with the axel shaft popping out ect.?
Anyone have a link to the price of the new redesigned Titan m205 front diff and Pathy half shafts?
Transfer cases and front diff's are not the same thing right? If they are then I can buy the right titan transfer case off of 4x4parts.com..??
Last edited by Servinhimonly : 07-09-2008 at 04:43 PM. Reason: Automerged Doublepost
Old 07-14-2008, 01:09 AM
Again, titans have alot more torque, which attributes to the diff failures. Including shafts popping due to clip failures. Those diffs are 25mm bigger than ours. us having R180As and Titans have M205's. We've had what...8 guys blow R180s? Out of how many? now add an INCH to the diff....
And why would you want a titan transfercase? To be honest, I'm not convinced we don't have the same unit. It wouldn't surprise me.
HTML code is On
